2.2.4 rc4 Issue
CudaNet
2.2.4 rc4 Issue
Post by CudaNet »
I recently upgraded to 2.2.4 rc4 but I've seem to have lost my Expert > Configuration. Clicking on Configuration takes me to the Expert Home screen. Any idea why or is there anything I can try. I've stepped back to rc1 but it's the same so obviously something was affected by the upgrade.
Thanks in advance.
CN
CudaNet
Re: 2.2.4 rc4 Issue
Post by CudaNet »
Just evaluated console (Chrome) and found the following...
CudaNet
Re: 2.2.4 rc4 Issue
Post by CudaNet »
So I upgraded to rc-5 and I can now enter configuration. However, whenever I toggle my lock. z-way crashes.
I'll get some logs together and post back..
CudaNet
Re: 2.2.4 rc4 Issue
Post by CudaNet »
And the logs, begins with command to lock the lock up until z-way crashes out.
[2016-08-20 14:27:36.649] [I] [core] ---  ZWayVDev_zway_18-0-98 performCommand processing: {"0":"close","1":{}}
[2016-08-20 14:27:36.657] [I] [zway] Adding job: Door Lock Operation Set
[2016-08-20 14:27:36.657] [I] [zway] Adding job: Door Lock Operation Get
[2016-08-20 14:27:36.660] [I] [zway] Node 18:0 CC Security: sending Nonce Get
[2016-08-20 14:27:36.660] [D] [zway] SETDATA devices.18.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2016-08-20 14:27:36.660] [I] [zway] Adding job: Nonce Get
[2016-08-20 14:27:36.660] [D] [zway] SETDATA devices.18.data.lastNonceGet = 6974 (0x00001b3e)
[2016-08-20 14:27:36.671] [D] [zway] SENDING (cb 0x05): ( 01 09 00 13 12 02 98 40 05 05 2D )
[2016-08-20 14:27:36.672] [D] [zway] RECEIVED ACK
[2016-08-20 14:27:36.676] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-08-20 14:27:36.676] [D] [zway] SENT ACK
[2016-08-20 14:27:36.676] [D] [zway] Delivered to Z-Wave stack
[2016-08-20 14:27:37.941] [D] [zway] RECEIVED: ( 01 07 00 13 05 00 00 7E 90 )
[2016-08-20 14:27:37.941] [D] [zway] SENT ACK
[2016-08-20 14:27:37.941] [I] [zway] Job 0x13 (Nonce Get): Delivered
[2016-08-20 14:27:37.941] [D] [zway] SETDATA controller.data.outgoingPacket.delivered = True
[2016-08-20 14:27:37.941] [D] [zway] SETDATA controller.data.outgoingPacket.deliveryTime = 1260 (0x000004ec)
[2016-08-20 14:27:37.942] [D] [zway] SETDATA controller.data.outgoingPacket.packetLength = 5 (0x00000005)
[2016-08-20 14:27:37.942] [D] [zway] SETDATA controller.data.outgoingPacket = **********
[2016-08-20 14:27:37.942] [D] [zway] SendData Response with callback 0x05 received: received by recipient
[2016-08-20 14:27:37.942] [D] [zway] SETDATA devices.18.data.lastSend = 7101 (0x00001bbd)
[2016-08-20 14:27:37.942] [D] [zway] Job 0x13 (Nonce Get): success
[2016-08-20 14:27:37.942] [D] [zway] SETDATA devices.18.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2016-08-20 14:27:37.942] [D] [zway] SETDATA devices.18.data.lastNonceGet = 7101 (0x00001bbd)
[2016-08-20 14:27:37.942] [I] [zway] Removing job: Nonce Get
[2016-08-20 14:27:38.043] [D] [zway] RECEIVED: ( 01 10 00 04 00 12 0A 98 80 C8 3C FD 4F 9A 00 C7 4D BD )
[2016-08-20 14:27:38.043] [D] [zway] SENT ACK
[2016-08-20 14:27:38.043] [D] [zway] SETDATA controller.data.incomingPacket.frameType = "singlecast"
[2016-08-20 14:27:38.044] [D] [zway] SETDATA controller.data.incomingPacket = **********
[2016-08-20 14:27:38.044] [D] [zway] SETDATA devices.18.data.lastReceived = 0 (0x00000000)
[2016-08-20 14:27:38.044] [I] [zway] Node 18:0 CC Security: received Nonce Report
[2016-08-20 14:27:38.044] [D] [zway] SETDATA devices.18.instances.0.commandClasses.152.data.rNonce = **********
[2016-08-20 14:27:38.044] [I] [zway] Node 18:0 CC Security: Sending a secure message
[2016-08-20 14:27:38.044] [I] [zway] Node 18:0 CC Security: sending encrypted packet: Door Lock Operation Set
[2016-08-20 14:27:38.044] [D] [zway] SETDATA devices.18.instances.0.commandClasses.152.data.toFollow = False
[2016-08-20 14:27:38.044] [D] [zway] SETDATA devices.18.data.lastNonceGet = Empty
[2016-08-20 14:27:38.045] [I] [zway] Adding job: Security, Door Lock Operation Set
[2016-08-20 14:27:38.045] [I] [zway] Node 18:0 CC Security: sending Nonce Get
[2016-08-20 14:27:38.045] [D] [zway] SETDATA devices.18.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2016-08-20 14:27:38.045] [I] [zway] Adding job: Nonce Get
[2016-08-20 14:27:38.045] [D] [zway] SETDATA devices.18.data.lastNonceGet = 7111 (0x00001bc7)
[2016-08-20 14:27:38.045] [D] [zway] SENDING (cb 0x06): ( 01 1E 00 13 12 17 98 81 D6 31 7E 3F 7A 68 7E 27 D1 AF FA 64 C8 A7 01 E2 31 D5 88 77 2A 05 06 5D )
[2016-08-20 14:27:38.053] [D] [zway] RECEIVED ACK
[2016-08-20 14:27:38.054] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-08-20 14:27:38.054] [D] [zway] SENT ACK
[2016-08-20 14:27:38.054] [I] [zway] Job 0x13 (Security, Door Lock Operation Set): Response received - transfered to encapsulated jobs
[2016-08-20 14:27:38.054] [D] [zway] Delivered to Z-Wave stack
[2016-08-20 14:27:38.073] [D] [zway] RECEIVED: ( 01 07 00 13 06 00 00 02 EF )
[2016-08-20 14:27:38.073] [D] [zway] SENT ACK
[2016-08-20 14:27:38.073] [I] [zway] Job 0x13 (Security, Door Lock Operation Set): Callback received - transfered to encapsulated jobs
[2016-08-20 14:27:38.073] [I] [zway] Job 0x13 (Door Lock Operation Set): Delivered
[2016-08-20 14:27:38.073] [D] [zway] SendData Response with callback 0x06 received: received by recipient
[2016-08-20 14:27:38.073] [D] [zway] Job 0x13 (Door Lock Operation Set): success
[2016-08-20 14:27:38.073] [I] [zway] Removing job: Door Lock Operation Set
[2016-08-20 14:27:38.073] [I] [zway] Job 0x13 (Security, Door Lock Operation Set): Delivered
[2016-08-20 14:27:38.074] [D] [zway] SETDATA controller.data.outgoingPacket.delivered = True
[2016-08-20 14:27:38.074] [D] [zway] SETDATA controller.data.outgoingPacket.deliveryTime = 20 (0x00000014)
[2016-08-20 14:27:38.074] [D] [zway] SETDATA controller.data.outgoingPacket.packetLength = 26 (0x0000001a)
[2016-08-20 14:27:38.074] [D] [zway] SETDATA controller.data.outgoingPacket = **********
[2016-08-20 14:27:38.074] [D] [zway] SendData Response with callback 0x06 received: received by recipient
[2016-08-20 14:27:38.074] [D] [zway] SETDATA devices.18.data.lastSend = 7114 (0x00001bca)
[2016-08-20 14:27:38.074] [D] [zway] Job 0x13 (Security, Door Lock Operation Set): success
[2016-08-20 14:27:38.074] [I] [zway] Removing job: Security, Door Lock Operation Set
[2016-08-20 14:27:38.143] [D] [zway] SENDING (cb 0x07): ( 01 09 00 13 12 02 98 40 05 07 2F )
[2016-08-20 14:27:38.144] [D] [zway] RECEIVED: ( 01 0C 00 04 00 0F 06 31 05 02 0A 0B 21 E8 )
[2016-08-20 14:27:38.144] [D] [zway] SENT ACK
[2016-08-20 14:27:38.144] [D] [zway] SETDATA controller.data.incomingPacket.frameType = "singlecast"
[2016-08-20 14:27:38.145] [D] [zway] SETDATA controller.data.incomingPacket = **********
[2016-08-20 14:27:38.145] [D] [zway] SETDATA devices.15.data.lastReceived = 0 (0x00000000)
[2016-08-20 14:27:38.145] [D] [zway] SETDATA devices.15.instances.0.commandClasses.49.data.2.deviceScale = 1 (0x00000001)
[2016-08-20 14:27:38.145] [D] [zway] SETDATA devices.15.instances.0.commandClasses.49.data.2.scale = 1 (0x00000001)
[2016-08-20 14:27:38.147] [D] [zway] SETDATA devices.15.instances.0.commandClasses.49.data.2.scaleString = ""
[2016-08-20 14:27:38.147] [D] [zway] SETDATA devices.15.instances.0.commandClasses.49.data.2.val = 2849.000000
[2016-08-20 14:27:38.148] [D] [zway] SETDATA devices.15.instances.0.commandClasses.49.data.2 = Empty
[2016-08-20 14:27:38.154] [D] [zway] RECEIVED CAN
[2016-08-20 14:27:38.453] [I] [zway] Job 0x13 (Nonce Get): No ACK received before timeout
[2016-08-20 14:27:38.453] [D] [zway] SENDING (cb 0x08): ( 01 09 00 13 12 02 98 40 05 08 20 )
[2016-08-20 14:27:38.455] [D] [zway] RECEIVED ACK
[2016-08-20 14:27:38.459] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-08-20 14:27:38.459] [D] [zway] SENT ACK
[2016-08-20 14:27:38.459] [D] [zway] Delivered to Z-Wave stack
[2016-08-20 14:27:38.475] [D] [zway] RECEIVED: ( 01 07 00 13 08 00 00 02 E1 )
[2016-08-20 14:27:38.475] [D] [zway] SENT ACK
[2016-08-20 14:27:38.475] [I] [zway] Job 0x13 (Nonce Get): Delivered
[2016-08-20 14:27:38.475] [D] [zway] SETDATA controller.data.outgoingPacket.delivered = True
[2016-08-20 14:27:38.475] [D] [zway] SETDATA controller.data.outgoingPacket.deliveryTime = 20 (0x00000014)
[2016-08-20 14:27:38.475] [D] [zway] SETDATA controller.data.outgoingPacket.packetLength = 5 (0x00000005)
Re: 2.2.4 rc4 Issue
There is a proble m with Security in RC5 on the Pi.
We will fix it soon.
Dont use RC versions until we suggest it
CudaNet
Re: 2.2.4 rc4 Issue
Post by CudaNet »
I reverted backto 2.2.3 and will await the final release of 2.2.4. As always, many thanks ..
CN
PoltoS wrote:There is a proble m with Security in RC5 on the Pi.
