Unable to download App
Dridl
Post by Dridl »
Hello!
I'm trying to install Zipato application from Online Apps and got an error Unable to download App
In log:
[2016-08-26 14:32:09.566] [E] [HTTP] Callback execution error: ReferenceError: installer is not defined
at AutomationController.installModule (automation/classes/AutomationController.js:589:9)
at ZAutomationAPIWebRequest._.extend.installModule (automation/ZAutomationAPIProvider.js:738:38)
at ZAutomationAPIWebRequest.ZAutomationWebRequest.handleRequest (automation/WebserverRequestRouter.js:258:41)
at automation/WebserverRequestRouter.js:32:35
at WebServer.document_root (automation/Webserver.js:29:11)
Same error with any application
Version number: v2.2.3-rc2
How to use Online Apps library?
Re: Unable to download App
Looks like you have some libraries missing
Please do
cd /opt/z-way-server; LD_LIBRARY_PATH=./libs ./z-way-server
You should see error message in furst 10 lines.
You can also do cd /opt/z-way-server; LD_LIBRARY_PATH=./libs ldd modules/modinstaller.so
Dridl
Post by Dridl »
This is Windows version of Z-way
Oh, have not got it. We will check it and get back to you
pah111kg
Post by pah111kg »
I get the same error on Windows and Z-Way Version v2.2.3-rc2.
Dridl
Post by Dridl »
Dear PoltoS, do you have any news about this problem?
PoltoS wrote:Oh, have not got it. We will check it and get back to you
Please check new v2.2.4. We have fixed few issues, but still on some windows it does not work. Will it for you?
pah111kg
Post by pah111kg »
Installing Z-Way apps now works for Windows 10 and Z-Way v2.2.4.
SReibert
Post by SReibert »
today we wanted to test a app from Zway Online App Store, but we have a big problem.
We installed a fresh Windows 7 x64, Windows 10 x64 and Ubuntu 16.04.x with only Zway Server 2.2.4 (Win), 2.2.5 (Ubuntu) and UZB Stick with zway license.
On all systems we had the same problem that we are not able to install online Apps. No matter which App, by pressing the "Download" Button it comes the Error Message: "Failed to install the App"
All OS have current updates.
How can we fix this?
Regards
Steffen
Failed to install App.PNG (25.28 KiB) Viewed 17097 times
