Many subdevices after inclusion on Fibaro HC2
Quikdav
Post by Quikdav »
Hi All
I modified the 10 channels sketch to create my own with only 7 channels.
ZUNO_SETUP_CHANNELS(
  ZUNO_SWITCH_BINARY(getterSwitch1, setterSwitch1),
  ZUNO_SWITCH_BINARY(getterSwitch2, setterSwitch2),
  ZUNO_SWITCH_BINARY(getterSwitch3, setterSwitch3),
  ZUNO_SENSOR_MULTILEVEL_CO2_LEVEL(getterMonoxyde),
  ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_CO2_LEVEL,  SENSOR_MULTILEVEL_SCALE_PERCENTAGE_VALUE, SENSOR_MULTILEVEL_SIZE_ONE_BYTE, SENSOR_MULTILEVEL_PRECISION_ZERO_DECIMALS, getterGazQuality),
  ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_LUMINANCE, SENSOR_MULTILEVEL_SCALE_PERCENTAGE_VALUE, SENSOR_MULTILEVEL_SIZE_ONE_BYTE, SENSOR_MULTILEVEL_PRECISION_ZERO_DECIMALS, getterLuminance),
  ZUNO_SENSOR_MULTILEVEL_TEMPERATURE(getterTemperature)
So it works fine but when I included it on a Fibaro HC2, I have 7 devices and for some of them, I have a child device. It is the case for luminance and temperature devices and for the main device.
It is not the case for the 2 CO2 sensors !!!
Is it normal or is it a random behaviour of HC2 ?
7 channels.png (53.96 KiB) Viewed 12070 times
Re: Many subdevices after inclusion on Fibaro HC2
This is normal. If you look carefully, 708.0 (main device) duplicates 708.1 (inside channel #1), 708.01 duplicates 708.4 (same), 708.6 looks like duplicate of 708.6.1 and 708.7 is 708.7.1 (these two are strange). First two are according to Z-Wave, the two last looks strange for us, may be some problem in HC2 mapping. What us your version of HC?
Chiquitoloco
Post by Chiquitoloco »
I got the behaviour with the example simple switch.
HC2 V4.090
Quikdav
Post by Quikdav »
My HC version is 4.090....
I thought that with 7 channels, I should have one main device and 7 child devices...so every 708.x child devices was normal but it is not the case...
I will create a ticket to fibaro support for more information
schmidmi
Post by schmidmi »
The problem with too many devices in HC2 (using the example sketch) van bee seen in V4.100 of the HC2
