HowTo refresh a virtual device?
ref: FAQ
I do have a problem with my Wunderground App (github) I moved some of the metrics to a newly created vDev for the wind direction
direction. However the metrics that I did move out, still show up in the JSON that I get from the device.
The image below show that "moved" metrics still showing up in the configjson file in folder stage
What can I do to resfresh these devices? The data marked in yellow is expired data. Even system reboot did not clean this up
Note: The device is found under the vdevInfo-branch
gsaw
Re: HowTo refresh a virtual device?
Post by gsaw »
pz1 wrote:I do have a problem with my Wunderground App (github) I moved some of the metrics to a newly created vDev for the wind direction
I guess you should to stop server, remove metrics manually from configjson and start server again. I had to do this, as i reworked OpenWheather for me for multiple devices. But i removed from config whole old device entry, created new module, then changed id of newly created device to old one in configjson.
gsaw wrote:I guess you should to stop server, remove metrics manually from configjson and start server again.
Thanks, I did just that, and it worked! Last time I edited this configjson 1-2 years ago it ended up in a big mess. Hence my question to the forum Apparantly the system and me have become more robust ;)
Side note: I do use Notepad++ as an editor. It does have a nice graphical tree browser on json, as can be seen in the first post
gsaw
Post by gsaw »
I installed a json pretty printing tool directly on my banana pi. It makes json file readable like on your screenshot. Then i can edit file using nano from my tablet, just i have to disable syntax highlighting in nano (alt-m) because configjson is to big for that.
georg@bananapi:~$ cat /opt/z-way-server/automation/storage/configjson-06b2d3b23dce96e1619d2b53d6c947ec.json | json_pp
   "profiles" : [
         "interval" : 2000,
         "hide_single_device_events" : [],
         "rooms" : [
            0
         "expert_view" : true,
         "name" : "Administrator",
         "password" : "admin",
         "lang" : "en",
         "dashboard" : [
            "ZWayVDev_zway_6-1-37",
            "ZWayVDev_zway_6-2-37",
            "LightScene_10",
            "LightScene_11",
            "LightScene_12",
            "ZWayVDev_zway_8-0-37",
            "ZWayVDev_zway_10-1-38",
            "ZWayVDev_zway_9-1-38",
            "ZWayVDev_zway_5-0-49-3",
            "LightScene_28",
            "ZWayVDev_zway_22-2-37",
            "ZWayVDev_zway_22-1-37",
            "Code_Device_sensorBinary_43",
            "Code_Device_sensorMultilevel_43",
            "Code_Device_sensorMultilevel_46"
         "hide_all_device_events" : false,
         "color" : "#dddddd",
gsaw wrote:I installed a json pretty printing tool directly on my banana pi.
Thanks for sharing. Do you have a reference? May be of interest to others
gsaw
Post by gsaw »
Oh, sorry, i dont know anymore, from which debian package exactly the script is. I just regulary installed several debian packages for json. There is one which is purposed for pretty printing.
georg@bananapi:~$ apt-cache search json | grep pretty
aeson-pretty - JSON pretty-printing tool
libghc-aeson-pretty-dev - JSON pretty-printing library
libghc-aeson-pretty-doc - JSON pretty-printing library; documentation
libghc-aeson-pretty-prof - JSON pretty-printing library; profiling libraries
try to install it with
sudo apt-get install aeson-pretty
