Razberry + BananaPi + Jeedom problem
benjisail
Post by benjisail »
I installed Jeedom + Razberry on a bananaPi v1, 2 years ago and everything worked fine until a month ago because of an SD card corruption.
I changed the SD card and did a fresh installation of raspian, jeedom and razberry software.
However I am not able to make the razberry to work.
I get the following error on the UI of http://MYIP:8083 :
Screen Shot 2016-10-04 at 07.12.20.png (166.48 KiB) Viewed 5069 times
I found here https://forum.z-wave.me/viewtopic.php?t=21064&p=54460 that I was suppose to change the port from http://MYIP:8083/z-way-ha/ but I get this error :
Screen Shot 2016-10-04 at 07.11.57.png (39.55 KiB) Viewed 5069 times
You will find below the log file with 2 different error.
Can it be an hardware problem with the razberry?
Thanks for your help!!
[2016-10-03 23:51:26.135] [I] [core] Executing script: exit()
[2016-10-03 23:51:46.229] [I] [core] Executing script: /*** Z-Way Home Automation Engine main executable ***************************** ...
[2016-10-03 23:51:46.235] [I] [core] Executing script: // Comon utilities and functions ...
[2016-10-03 23:51:46.249] [I] [core] Executing script: // This script transforms old formats to new ...
[2016-10-03 23:51:50.684] [I] [core] Executing script: /*! ...
[2016-10-03 23:51:52.501] [I] [core] Executing script: //     Underscore.js 1.7.0 ...
[2016-10-03 23:51:59.551] [I] [core] Executing script: /*! ...
[2016-10-03 23:51:59.991] [I] [core] Executing script: /*** Z-Way HA Virtual Device base class *************************************** ...
[2016-10-03 23:52:00.001] [I] [core] Executing script: /*** Z-Way DevicesCollection class ************************************ ...
[2016-10-03 23:52:01.213] [I] [core] Executing script: /*** Z-Way HA Controller class module ***************************************** ...
[2016-10-03 23:52:01.273] [I] [core] Executing script: /*** Automation Webserver Auth Controller ************************************* ...
[2016-10-03 23:52:01.305] [I] [core] Executing script: /*** Z-Way HA Automation module base class ************************************ ...
[2016-10-03 23:52:01.313] [I] [core] Executing script:  ...
[2016-10-03 23:52:01.344] [I] [core] Executing script: /*** Main Automation storage module ***************************************** ...
[2016-10-03 23:52:01.395] [I] [core] Executing script: /*** Main Automation webserver module ***************************************** ...
[2016-10-03 23:52:01.411] [I] [core] Executing script: // Make this testable by pulling in underscore from the parent module ...
[2016-10-03 23:52:01.431] [I] [core] Executing script: /*** Main Automation storage module ***************************************** ...
[2016-10-03 23:52:01.469] [I] [core] --- Loading ZAutomation classes
[2016-10-03 23:52:03.456] [I] [core] Starting ZWay Automation webserver
[2016-10-03 23:52:03.485] [I] [core] Loading modules...
[2016-10-03 23:52:03.533] [I] [core] Loading module ZWave from modules/ZWave
[2016-10-03 23:52:03.583] [I] [core] Executing script: /*** Z-Wave Binding module ******************************************************** ...
[2016-10-03 23:52:03.682] [I] [core] Instantiating module 1 from class ZWave
[2016-10-03 23:52:03.686] [I] [core] --- Starting module Z-Wave Network Access
[2016-10-03 23:52:04.858] [D] [zway] SETDATA controller.data = Empty
[2016-10-03 23:52:04.859] [D] [zway] SETDATA controller.data.nodeId = Empty
[2016-10-03 23:52:04.859] [D] [zway] SETDATA controller.data.homeId = Empty
[2016-10-03 23:52:04.859] [D] [zway] SETDATA controller.data.SUCNodeId = Empty
[2016-10-03 23:52:04.859] [D] [zway] SETDATA controller.data.isPrimary = Empty
[2016-10-03 23:52:04.859] [D] [zway] SETDATA controller.data.isInOthersNetwork = Empty
[2016-10-03 23:52:04.859] [D] [zway] SETDATA controller.data.isRealPrimary = Empty
[2016-10-03 23:52:04.859] [D] [zway] SETDATA controller.data.isSUC = Empty
[2016-10-03 23:52:04.859] [D] [zway] SETDATA controller.data.SISPresent = Empty
[2016-10-03 23:52:04.859] [D] [zway] SETDATA controller.data.libType = Empty
[2016-10-03 23:52:04.859] [D] [zway] SETDATA controller.data.SDK = Empty
[2016-10-03 23:52:04.859] [D] [zway] SETDATA controller.data.ZWlibMajor = Empty
[2016-10-03 23:52:04.859] [D] [zway] SETDATA controller.data.ZWlibMinor = Empty
[2016-10-03 23:52:04.859] [D] [zway] SETDATA controller.data.ZWLib = Empty
[2016-10-03 23:52:04.859] [D] [zway] SETDATA controller.data.ZWVersion = Empty
[2016-10-03 23:52:04.860] [D] [zway] SETDATA controller.data.ZWaveChip = Empty
[2016-10-03 23:52:04.860] [D] [zway] SETDATA controller.data.APIVersion = Empty
[2016-10-03 23:52:04.860] [D] [zway] SETDATA controller.data.manufacturerId = Empty
[2016-10-03 23:52:04.860] [D] [zway] SETDATA controller.data.vendor = Empty
[2016-10-03 23:52:04.860] [D] [zway] SETDATA controller.data.manufacturerProductType = Empty
[2016-10-03 23:52:04.860] [D] [zway] SETDATA controller.data.manufacturerProductId = Empty
[2016-10-03 23:52:04.860] [D] [zway] SETDATA controller.data.capabilities = Empty
[2016-10-03 23:52:04.860] [D] [zway] SETDATA controller.data.controllerState = Empty
[2016-10-03 23:52:04.860] [D] [zway] SETDATA controller.data.nonManagmentJobs = Empty
[2016-10-03 23:52:04.860] [D] [zway] SETDATA controller.data.lastIncludedDevice = Empty
[2016-10-03 23:52:04.860] [D] [zway] SETDATA controller.data.lastExcludedDevice = Empty
[2016-10-03 23:52:04.860] [D] [zway] SETDATA controller.data.secureInclusion = Empty
[2016-10-03 23:52:04.860] [D] [zway] SETDATA controller.data.oldSerialAPIAckTimeout10ms = Empty
[2016-10-03 23:52:04.860] [D] [zway] SETDATA controller.data.oldSerialAPIByteTimeout10ms = Empty
[2016-10-03 23:52:04.860] [D] [zway] SETDATA controller.data.curSerialAPIAckTimeout10ms = Empty
[2016-10-03 23:52:04.860] [D] [zway] SETDATA controller.data.curSerialAPIByteTimeout10ms = Empty
[2016-10-03 23:52:04.861] [D] [zway] SETDATA controller.data.countJobs = Empty
[2016-10-03 23:52:04.861] [D] [zway] SETDATA controller.data.memoryGetAddress = Empty
[2016-10-03 23:52:04.861] [D] [zway] SETDATA controller.data.memoryGetData = Empty
[2016-10-03 23:52:04.861] [D] [zway] SETDATA controller.data.functionClasses = Empty
[2016-10-03 23:52:04.861] [D] [zway] SETDATA controller.data.functionClassesNames = Empty
[2016-10-03 23:52:04.861] [D] [zway] SETDATA controller.data.softwareRevisionVersion = Empty
[2016-10-03 23:52:04.861] [D] [zway] SETDATA controller.data.softwareRevisionId = Empty
[2016-10-03 23:52:04.861] [D] [zway] SETDATA controller.data.softwareRevisionDate = Empty
[2016-10-03 23:52:04.861] [D] [zway] SETDATA controller.data.uuid = Empty
[2016-10-03 23:52:04.861] [D] [zway] SETDATA controller.data.caps = Empty
[2016-10-03 23:52:04.861] [D] [zway] SETDATA controller.data.frequency = Empty
[2016-10-03 23:52:04.861] [D] [zway] SETDATA controller.data.deviceRelaxDelay = Empty
[2016-10-03 23:52:04.861] [D] [zway] SETDATA controller.data.nodeId = 0 (0x00000000)
[2016-10-03 23:52:04.861] [D] [zway] SETDATA controller.data.homeId = 0 (0x00000000)
[2016-10-03 23:52:04.861] [D] [zway] SETDATA controller.data.SUCNodeId = 0 (0x00000000)
[2016-10-03 23:52:04.862] [D] [zway] SETDATA controller.data.isPrimary = False
[2016-10-03 23:52:04.862] [D] [zway] SETDATA controller.data.isInOthersNetwork = False
[2016-10-03 23:52:04.862] [D] [zway] SETDATA controller.data.isRealPrimary = False
[2016-10-03 23:52:04.862] [D] [zway] SETDATA controller.data.isSUC = False
[2016-10-03 23:52:04.862] [D] [zway] SETDATA controller.data.SISPresent = False
[2016-10-03 23:52:04.862] [D] [zway] SETDATA controller.data.ZWLib = 0 (0x00000000)
[2016-10-03 23:52:04.862] [D] [zway] SETDATA controller.data.ZWlibMajor = 0 (0x00000000)
[2016-10-03 23:52:04.862] [D] [zway] SETDATA controller.data.ZWlibMinor = 0 (0x00000000)
[2016-10-03 23:52:04.862] [D] [zway] SETDATA controller.data.ZWVersion = 0 (0x00000000)
[2016-10-03 23:52:04.862] [D] [zway] SETDATA controller.data.manufacturerId = 0 (0x00000000)
[2016-10-03 23:52:04.862] [D] [zway] SETDATA controller.data.manufacturerProductType = 0 (0x00000000)
[2016-10-03 23:52:04.862] [D] [zway] SETDATA controller.data.manufacturerProductId = 0 (0x00000000)
[2016-10-03 23:52:04.862] [D] [zway] SETDATA controller.data.controllerState = 0 (0x00000000)
[2016-10-03 23:52:04.862] [D] [zway] SETDATA controller.data.nonManagmentJobs = 0 (0x00000000)
[2016-10-03 23:52:04.862] [D] [zway] SETDATA controller.data.secureInclusion = True
[2016-10-03 23:52:04.862] [D] [zway] SETDATA controller.data.oldSerialAPIAckTimeout10ms = 0 (0x00000000)
[2016-10-03 23:52:04.862] [D] [zway] SETDATA controller.data.oldSerialAPIByteTimeout10ms = 0 (0x00000000)
[2016-10-03 23:52:04.862] [D] [zway] SETDATA controller.data.curSerialAPIAckTimeout10ms = 0 (0x00000000)
[2016-10-03 23:52:04.862] [D] [zway] SETDATA controller.data.curSerialAPIByteTimeout10ms = 0 (0x00000000)
[2016-10-03 23:52:04.862] [D] [zway] SETDATA controller.data.countJobs = False
[2016-10-03 23:52:04.863] [D] [zway] SETDATA controller.data.softwareRevisionVersion = "v2.2.3"
[2016-10-03 23:52:04.863] [D] [zway] SETDATA controller.data.softwareRevisionId = "fcbcb6053bf804b759347cc77102329126eb5a26"
[2016-10-03 23:52:04.863] [D] [zway] SETDATA controller.data.softwareRevisionDate = "2016-07-12 18:09:13 +0300"
[2016-10-03 23:52:04.863] [D] [zway] SETDATA controller.data.deviceRelaxDelay = 5 (0x00000005)
[2016-10-03 23:52:04.864] [D] [zway] SETDATA controller.data.functionClasses = int[56]
[2016-10-03 23:52:04.864] [D] [zway]   [00] 2
[2016-10-03 23:52:04.864] [D] [zway]   [01] 3
[2016-10-03 23:52:04.864] [D] [zway]   [02] 4
[2016-10-03 23:52:04.864] [D] [zway]   [03] 5
[2016-10-03 23:52:04.864] [D] [zway]   [04] 6
[2016-10-03 23:52:04.864] [D] [zway]   [05] 7
[2016-10-03 23:52:04.869] [D] [zway]   [06] 8
[2016-10-03 23:52:04.870] [D] [zway]   [07] 18
[2016-10-03 23:52:04.870] [D] [zway]   [08] 19
[2016-10-03 23:52:04.870] [D] [zway]   [09] 21
[2016-10-03 23:52:04.870] [D] [zway]   [10] 22
[2016-10-03 23:52:04.870] [D] [zway]   [11] 23
[2016-10-03 23:52:04.870] [D] [zway]   [12] 32
[2016-10-03 23:52:04.870] [D] [zway]   [13] 33
[2016-10-03 23:52:04.870] [D] [zway]   [14] 34
[2016-10-03 23:52:04.870] [D] [zway]   [15] 35
[2016-10-03 23:52:04.870] [D] [zway]   [16] 36
[2016-10-03 23:52:04.870] [D] [zway]   [17] 39
[2016-10-03 23:52:04.870] [D] [zway]   [18] 41
[2016-10-03 23:52:04.870] [D] [zway]   [19] 42
[2016-10-03 23:52:04.870] [D] [zway]   [20] 43
[2016-10-03 23:52:04.870] [D] [zway]   [21] 44
[2016-10-03 23:52:04.870] [D] [zway]   [22] 45
[2016-10-03 23:52:04.871] [D] [zway]   [23] 65
[2016-10-03 23:52:04.871] [D] [zway]   [24] 66
[2016-10-03 23:52:04.871] [D] [zway]   [25] 68
[2016-10-03 23:52:04.871] [D] [zway]   [26] 70
[2016-10-03 23:52:04.871] [D] [zway]   [27] 71
[2016-10-03 23:52:04.871] [D] [zway]   [28] 72
[2016-10-03 23:52:04.871] [D] [zway]   [29] 73
[2016-10-03 23:52:04.871] [D] [zway]   [30] 74
[2016-10-03 23:52:04.871] [D] [zway]   [31] 75
[2016-10-03 23:52:04.871] [D] [zway]   [32] 76
[2016-10-03 23:52:04.871] [D] [zway]   [33] 77
[2016-10-03 23:52:04.871] [D] [zway]   [34] 80
[2016-10-03 23:52:04.871] [D] [zway]   [35] 81
[2016-10-03 23:52:04.871] [D] [zway]   [36] 82
[2016-10-03 23:52:04.871] [D] [zway]   [37] 83
[2016-10-03 23:52:04.871] [D] [zway]   [38] 84
[2016-10-03 23:52:04.871] [D] [zway]   [39] 85
[2016-10-03 23:52:04.871] [D] [zway]   [40] 86
[2016-10-03 23:52:04.878] [D] [zway]   [41] 87
[2016-10-03 23:52:04.878] [D] [zway]   [42] 94
[2016-10-03 23:52:04.878] [D] [zway]   [43] 96
[2016-10-03 23:52:04.878] [D] [zway]   [44] 97
[2016-10-03 23:52:04.878] [D] [zway]   [45] 98
[2016-10-03 23:52:04.878] [D] [zway]   [46] 99
[2016-10-03 23:52:04.878] [D] [zway]   [47] 128
[2016-10-03 23:52:04.878] [D] [zway]   [48] 186
[2016-10-03 23:52:04.878] [D] [zway]   [49] 190
[2016-10-03 23:52:04.878] [D] [zway]   [50] 210
[2016-10-03 23:52:04.878] [D] [zway]   [51] 211
[2016-10-03 23:52:04.879] [D] [zway]   [52] 242
[2016-10-03 23:52:04.879] [D] [zway]   [53] 243
[2016-10-03 23:52:04.879] [D] [zway]   [54] 244
[2016-10-03 23:52:04.879] [D] [zway]   [55] 245
[2016-10-03 23:52:04.882] [D] [zway] SETDATA controller.data.functionClassesNames = string[56]
[2016-10-03 23:52:04.882] [D] [zway]   [00] "SerialAPIGetInitData"
[2016-10-03 23:52:04.882] [D] [zway]   [01] "SerialAPIApplicationNodeInformation"
[2016-10-03 23:52:04.882] [D] [zway]   [02] "ApplicationCommandHandler"
[2016-10-03 23:52:04.882] [D] [zway]   [03] "GetControllerCapabilities"
[2016-10-03 23:52:04.882] [D] [zway]   [04] "SerialAPISetTimeouts"
[2016-10-03 23:52:04.882] [D] [zway]   [05] "GetSerialAPICapabilities"
[2016-10-03 23:52:04.882] [D] [zway]   [06] "SerialAPISoftReset"
[2016-10-03 23:52:04.882] [D] [zway]   [07] "SendNodeInformation"
[2016-10-03 23:52:04.882] [D] [zway]   [08] "SendData"
[2016-10-03 23:52:04.882] [D] [zway]   [09] "GetVersion"
[2016-10-03 23:52:04.883] [D] [zway]   [10] "SendDataAbort"
[2016-10-03 23:52:04.883] [D] [zway]   [11] "RFPowerLevelSet"
[2016-10-03 23:52:04.883] [D] [zway]   [12] "GetHomeId"
[2016-10-03 23:52:04.883] [D] [zway]   [13] "MemoryGetByte"
[2016-10-03 23:52:04.883] [D] [zway]   [14] "MemoryPutByte"
[2016-10-03 23:52:04.883] [D] [zway]   [15] "MemoryGetBuffer"
[2016-10-03 23:52:04.883] [D] [zway]   [16] "MemoryPutBuffer"
[2016-10-03 23:52:04.883] [D] [zway]   [17] "FlashAutoProgSet"
[2016-10-03 23:52:04.883] [D] [zway]   [18] "NVMGetId"
[2016-10-03 23:52:04.883] [D] [zway]   [19] "NVMExtReadLongBuffer"
[2016-10-03 23:52:04.883] [D] [zway]   [20] "NVMExtWriteLongBuffer"
[2016-10-03 23:52:04.883] [D] [zway]   [21] "NVMExtReadLongByte"
[2016-10-03 23:52:04.883] [D] [zway]   [22] "NVMExtWriteLongByte"
[2016-10-03 23:52:04.883] [D] [zway]   [23] "GetNodeProtocolInformation"
[2016-10-03 23:52:04.883] [D] [zway]   [24] "SetDefault"
[2016-10-03 23:52:04.883] [D] [zway]   [25] "ReplicationReceiveComplete"
[2016-10-03 23:52:04.883] [D] [zway]   [26] "AssignReturnRoute"
[2016-10-03 23:52:04.883] [D] [zway]   [27] "DeleteReturnRoute"
[2016-10-03 23:52:04.883] [D] [zway]   [28] "RequestNodeNeighbourUpdate"
[2016-10-03 23:52:04.883] [D] [zway]   [29] "ApplicationNodeUpdate"
[2016-10-03 23:52:04.884] [D] [zway]   [30] "AddNodeToNetwork"
[2016-10-03 23:52:04.884] [D] [zway]   [31] "RemoveNodeFromNetwork"
[2016-10-03 23:52:04.889] [D] [zway]   [32] "CreateNewPrimary"
[2016-10-03 23:52:04.889] [D] [zway]   [33] "ControllerChange"
[2016-10-03 23:52:04.889] [D] [zway]   [34] "SetLearnMode"
[2016-10-03 23:52:04.889] [D] [zway]   [35] "AssignSUCReturnRoute"
[2016-10-03 23:52:04.889] [D] [zway]   [36] "EnableSUC"
[2016-10-03 23:52:04.889] [D] [zway]   [37] "RequestNetworkUpdate"
[2016-10-03 23:52:04.889] [D] [zway]   [38] "SetSUCNodeId"
[2016-10-03 23:52:04.889] [D] [zway]   [39] "DeleteSUCReturnRoute"
[2016-10-03 23:52:04.889] [D] [zway]   [40] "GetSUCNodeId"
[2016-10-03 23:52:04.889] [D] [zway]   [41] "SendSUCNodeId"
[2016-10-03 23:52:04.890] [D] [zway]   [42] "ExploreRequestInclusion"
[2016-10-03 23:52:04.890] [D] [zway]   [43] "RequestNodeInformation"
[2016-10-03 23:52:04.890] [D] [zway]   [44] "RemoveFailedNode"
[2016-10-03 23:52:04.890] [D] [zway]   [45] "IsFailedNode"
[2016-10-03 23:52:04.890] [D] [zway]   [46] "ReplaceFailedNode"
[2016-10-03 23:52:04.890] [D] [zway]   [47] "GetRoutingTableLine"
[2016-10-03 23:52:04.890] [D] [zway]   [48] "RFPowerLevelGet"
[2016-10-03 23:52:04.890] [D] [zway]   [49] "SendTestFrame"
[2016-10-03 23:52:04.890] [D] [zway]   [50] "WatchDogStart"
[2016-10-03 23:52:04.890] [D] [zway]   [51] "WatchDogStop"
[2016-10-03 23:52:04.890] [D] [zway]   [52] "ZMEFreqChange"
[2016-10-03 23:52:04.890] [D] [zway]   [53] "ZMERestore"
[2016-10-03 23:52:04.890] [D] [zway]   [54] "ZMEBootloaderFlash"
[2016-10-03 23:52:04.890] [D] [zway]   [55] "ZMECapabilities"
[2016-10-03 23:52:04.891] [C] [i/o] Failed to open device /dev/ttyAMA0: No such file or directory
[2016-10-03 23:52:04.907] [E] [zway] SaveData will not save data since it wasn't loaded. This is to prevent data loss.
[2016-10-03 23:52:05.022] [I] [core] Notification: critical (z-wave): Cannot start Z-Wave binding: Error: Invalid port
[2016-10-03 23:52:05.042] [I] [core] Loading module Cron from modules/Cron
[2016-10-03 23:52:05.102] [I] [core] Executing script: /*** Cron ZAutomation module ************************************************** ...
[2016-10-03 23:52:05.135] [I] [core] Instantiating module 2 from class Cron
[2016-10-03 23:52:05.150] [I] [core] --- Starting module System Clock (CRON)
[2016-10-03 23:52:05.193] [I] [core] Loading module HTTPDevice from modules/HTTPDevice
[2016-10-03 23:52:05.462] [I] [core] Executing script: /*** HTTPDevice Z-Way HA module ******************************************* ...
[2016-10-03 23:52:05.465] [I] [core] Loading module SmartLight from modules/SmartLight
[2016-10-03 23:52:05.491] [I] [core] Executing script: /*** SmartLight Z-Way Home Automation module ************************************* ...
[2016-10-03 23:52:05.493] [I] [core] Loading module Camera from modules/Camera
[2016-10-03 23:52:05.507] [I] [core] Executing script: /*** Camera Z-Way HA module ******************************************* ...
[2016-10-03 23:52:05.517] [I] [core] Loading module PoppCam from modules/PoppCam
[2016-10-03 23:52:05.541] [I] [core] Executing script: /*** PoppCam Z-Way HA module ******************************************* ...
[2016-10-03 23:52:05.546] [I] [core] Loading module FosCam9826 from modules/FosCam9826
[2016-10-03 23:52:05.589] [I] [core] Executing script: /*** FosCam9826 Z-Way HA module ******************************************* ...
[2016-10-03 23:52:05.594] [I] [core] Loading module DelayedScene from modules/DelayedScene
[2016-10-03 23:52:05.608] [I] [core] Executing script: /*** DelayedScene Z-Way HA module ******************************************* ...
[2016-10-03 23:52:05.611] [I] [core] Loading module FosCam9828 from modules/FosCam9828
[2016-10-03 23:52:05.627] [I] [core] Executing script: /*** FosCam9828 Z-Way HA module ******************************************* ...
[2016-10-03 23:52:05.630] [I] [core] Loading module SwitchControlGenerator from modules/SwitchControlGenerator
[2016-10-03 23:52:05.648] [I] [core] Executing script: /*** SwitchControlGenerator Z-Way HA module ******************************************* ...
[2016-10-03 23:52:05.685] [I] [core] Instantiating module 8 from class SwitchControlGenerator
[2016-10-03 23:52:05.700] [I] [core] --- Starting module Trap events from Remotes and Sensors
[2016-10-03 23:52:05.711] [I] [core] Loading module AutoOff from modules/AutoOff
[2016-10-03 23:52:05.721] [I] [core] Executing script: /*** AutoOff Z-Way Home Automation module ************************************* ...
[2016-10-03 23:52:05.724] [I] [core] Loading module CustomUserCode from modules/CustomUserCode
[2016-10-03 23:52:05.738] [I] [core] Executing script:   /*** CustomUserCode ZAutomation module **************************************** ...
[2016-10-03 23:52:05.740] [I] [core] Loading module RemoteAccess from modules/RemoteAccess
[2016-10-03 23:52:05.756] [I] [core] Executing script: /*** RemoteAccess Z-Way HA module ******************************************* ...
[2016-10-03 23:52:05.783] [I] [core] Instantiating module 4 from class RemoteAccess
[2016-10-03 23:52:05.805] [I] [core] --- Starting module Remote Access
[2016-10-03 23:52:06.649] [I] [core] success! start zbw ...
[2016-10-03 23:52:06.656] [I] [core] Loading module DummyDevice from modules/DummyDevice
[2016-10-03 23:52:06.677] [I] [core] Executing script: /*** DummyDevice Z-Way HA module ******************************************* ...
[2016-10-03 23:52:06.684] [I] [core] Loading module SensorsPolling from modules/SensorsPolling
[2016-10-03 23:52:06.710] [I] [core] Executing script: /*** SensorsPolling Z-Way HA module ******************************************* ...
[2016-10-03 23:52:06.728] [I] [core] Instantiating module 6 from class SensorsPolling
[2016-10-03 23:52:06.735] [I] [core] --- Starting module Periodical Sensor Polling
[2016-10-03 23:52:06.827] [I] [core] Loading module ScheduledScene from modules/ScheduledScene
[2016-10-03 23:52:06.836] [I] [core] Executing script: /*** ScheduledScene Z-Way HA module ******************************************* ...
[2016-10-03 23:52:06.838] [I] [core] Loading module AutoLock from modules/AutoLock
[2016-10-03 23:52:06.873] [I] [core] Executing script: /*** AutoLock Z-Way Home Automation module ************************************* ...
[2016-10-03 23:52:06.888] [I] [core] Loading module VistaCam from modules/VistaCam
[2016-10-03 23:52:06.893] [I] [core] Executing script: /*** VistaCam Z-Way HA module ******************************************* ...
[2016-10-03 23:52:06.896] [I] [core] Loading module GroupDevices from modules/GroupDevices
[2016-10-03 23:52:06.916] [I] [core] Executing script: /*** GroupDevices Z-Way HA module ******************************************* ...
[2016-10-03 23:52:06.918] [I] [core] Loading module LightScene from modules/LightScene
[2016-10-03 23:52:06.939] [I] [core] Executing script: /*** LightScene Z-Way HA module ******************************************* ...
[2016-10-03 23:52:06.941] [I] [core] Loading module MultilineSensor from modules/MultilineSensor
[2016-10-03 23:52:06.974] [I] [core] Executing script: /*** MultilineSensor Z-Way HA module ******************************************* ...
[2016-10-03 23:52:06.976] [I] [core] Loading module NotificationSMSru from modules/NotificationSMSru
[2016-10-03 23:52:06.990] [I] [core] Executing script: /*** NotificationSMSru Z-Way HA module ******************************************* ...
[2016-10-03 23:52:06.993] [I] [core] Loading module SensorValueLogging from modules/SensorValueLogging
[2016-10-03 23:52:07.000] [I] [core] Executing script: /*** SensorValueLogging Z-Way Home Automation module ************************************* ...
[2016-10-03 23:52:07.006] [I] [core] Loading module RGB from modules/RGB
[2016-10-03 23:52:07.015] [I] [core] Executing script: /*** RGB Z-Way HA module ******************************************* ...
[2016-10-03 23:52:07.028] [I] [core] Loading module TagOnOff from modules/TagOnOff
[2016-10-03 23:52:07.033] [I] [core] Executing script: /*** TagOnOff Z-Way HA module ******************************************* ...
[2016-10-03 23:52:07.042] [I] [core] Loading module DeviceHistory from modules/DeviceHistory
[2016-10-03 23:52:07.054] [I] [core] Executing script: /*** DeviceHistory Z-Way HA module ******************************************* ...
[2016-10-03 23:52:07.073] [I] [core] Loading module FosCam9805 from modules/FosCam9805
[2016-10-03 23:52:07.083] [I] [core] Executing script: /*** FosCam9805 Z-Way HA module ******************************************* ...
[2016-10-03 23:52:07.086] [I] [core] Loading module GlobalCache from modules/GlobalCache
[2016-10-03 23:52:07.098] [I] [core] Executing script: /*** GlobalCache Z-Way HA module ******************************************* ...
[2016-10-03 23:52:07.101] [I] [core] Loading module LogicalRules from modules/LogicalRules
[2016-10-03 23:52:07.121] [I] [core] Executing script: /*** LogicalRules Z-Way HA module ******************************************* ...
[2016-10-03 23:52:07.146] [I] [core] Loading module ThermostatDevice from modules/ThermostatDevice
[2016-10-03 23:52:07.154] [I] [core] Executing script: /*** ThermostatDevice Z-Way HA module ******************************************* ...
[2016-10-03 23:52:07.163] [I] [core] Loading module CodeDevice from modules/CodeDevice
[2016-10-03 23:52:07.169] [I] [core] Executing script: /*** CodeDevice Z-Way HA module ******************************************* ...
[2016-10-03 23:52:07.171] [I] [core] Loading module ImportRemoteHA from modules/ImportRemoteHA
[2016-10-03 23:52:07.200] [I] [core] Executing script: /*** ImportRemoteHA Z-Way HA module ******************************************* ...
[2016-10-03 23:52:07.202] [I] [core] Loading module LightMotionRockerAutocontrol from modules/LightMotionRockerAutocontrol
[2016-10-03 23:52:07.222] [I] [core] Executing script: /*** LightMotionRockerAutocontrol Z-Way Home Automation module ************************************* ...
[2016-10-03 23:52:07.226] [I] [core] Loading module InbandNotifications from modules/InbandNotifications
[2016-10-03 23:52:07.246] [I] [core] Executing script: /*** InbandNotifications Z-Way HA module ******************************************* ...
[2016-10-03 23:52:07.281] [I] [core] Instantiating module 3 from class InbandNotifications
[2016-10-03 23:52:07.293] [I] [core] --- Starting module Inband Notifier
[2016-10-03 23:52:07.339] [I] [core] Loading module CounterTriggeringSensor from modules/CounterTriggeringSensor
[2016-10-03 23:52:07.354] [I] [core] Executing script: /*** Counter triggering binary sensor Z-Way HA module ******************************************* ...
[2016-10-03 23:52:07.374] [I] [core] Loading module SensorsPollingLogging from modules/SensorsPollingLogging
[2016-10-03 23:52:07.383] [I] [core] Executing script: /*** SensorsPollingLogging Z-Way HA module ******************************************* ...
[2016-10-03 23:52:07.386] [I] [core] Loading module Sonos from modules/Sonos
[2016-10-03 23:52:07.422] [I] [core] Executing script: /*** Sonos Z-Way HA module ******************************************* ...
[2016-10-03 23:52:07.429] [I] [core] Loading module EnOcean from modules/EnOcean
[2016-10-03 23:52:07.441] [I] [core] Executing script: /*** EnOcean Binding module ******************************************************** ...
[2016-10-03 23:52:07.473] [I] [core] Loading module OpenWeather from modules/OpenWeather
[2016-10-03 23:52:07.499] [I] [core] Executing script: /*** OpenWeather Extended Z-Way HA module ******************************************* ...
[2016-10-03 23:52:07.501] [I] [core] Loading module Notification from modules/Notification
[2016-10-03 23:52:07.506] [I] [core] Executing script: /*** Notification Z-Way HA module ******************************************* ...
[2016-10-03 23:52:07.520] [I] [core] Loading module SwitchPolling from modules/SwitchPolling
[2016-10-03 23:52:07.529] [I] [core] Executing script: /*** SwitchPolling Z-Way HA module ******************************************* ...
[2016-10-03 23:52:07.532] [I] [core] Loading module BatteryPolling from modules/BatteryPolling
[2016-10-03 23:52:07.561] [I] [core] Executing script: /*** BatteryPolling Z-Way HA module ******************************************* ...
[2016-10-03 23:52:07.586] [I] [core] Instantiating module 7 from class BatteryPolling
[2016-10-03 23:52:07.591] [I] [core] --- Starting module Battery Polling
[2016-10-03 23:52:07.611] [I] [core] Creating device battery BatteryPolling_7
[2016-10-03 23:52:07.742] [I] [core] Loading module ZMEOpenWRT from modules/ZMEOpenWRT
[2016-10-03 23:52:07.746] [I] [core] Executing script: /*** ZMEOpenWRT Z-Way HA module ******************************************* ...
[2016-10-03 23:52:07.748] [I] [core] Loading module CustomUserCodeLoader from modules/CustomUserCodeLoader
[2016-10-03 23:52:07.751] [I] [core] Executing script:   /*** CustomUserCodeLoader ZAutomation module **************************************** ...
[2016-10-03 23:52:07.753] [I] [core] Loading module OpenRemoteHelpers from modules/OpenRemoteHelpers
[2016-10-03 23:52:07.762] [I] [core] Executing script: /* RaZOR ...
[2016-10-03 23:52:07.765] [I] [core] Loading module IfThen from modules/IfThen
[2016-10-03 23:52:07.769] [I] [core] Executing script: /*** IfThen Z-Way HA module ******************************************* ...
[2016-10-03 23:52:07.771] [I] [core] Loading module PhilioHW from modules/PhilioHW
[2016-10-03 23:52:07.779] [I] [core] Executing script: /*** PhilioHW Z-Way HA module ******************************************* ...
[2016-10-03 23:52:07.782] [I] [core] Loading module InfoWidget from modules/InfoWidget
[2016-10-03 23:52:07.797] [I] [core] Executing script: /*** InfoWidget Z-Way HA module ******************************************* ...
[2016-10-03 23:52:07.811] [I] [core] Instantiating module 5 from class InfoWidget
[2016-10-03 23:52:07.818] [I] [core] --- Starting module Information Widget
[2016-10-03 23:53:33.112] [I] [core] Creating device text InfoWidget_5_Int
[2016-10-03 23:53:33.178] [I] [core] Loading module CustomUserCodeZWay from modules/CustomUserCodeZWay
[2016-10-03 23:53:33.182] [I] [core] Executing script:   /*** CustomUserCodeZWay ZAutomation module **************************************** ...
[2016-10-03 23:53:33.184] [I] [core] Loading module SecurityMode from modules/SecurityMode
[2016-10-03 23:53:33.199] [I] [core] Executing script: /*** SecurityMode Z-Way HA module ******************************************* ...
[2016-10-03 23:53:33.210] [I] [core] Loading module RoundRobinScenes from modules/RoundRobinScenes
[2016-10-03 23:53:33.214] [I] [core] Executing script: /*** RoundRobinScenes Z-Way HA module ******************************************* ...
[2016-10-03 23:53:33.217] [I] [core] Loading module BindDevices from modules/BindDevices
[2016-10-03 23:53:33.225] [I] [core] Executing script: /*** BindDevices Z-Way HA module ******************************************* ...
[2016-10-03 23:53:33.228] [I] [core] Loading module FosCam9821 from modules/FosCam9821
[2016-10-03 23:53:33.237] [I] [core] Executing script: /*** FosCam9821 Z-Way HA module ******************************************* ...
[2016-10-03 23:53:33.240] [I] [core] Starting automation...
[2016-10-03 23:53:33.341] [I] [core] Starting storage...
[2016-10-03 23:53:33.344] [I] [core] ZWay Automation started
[2016-10-04 00:06:37.322] [I] [core] Executing script: /*** Z-Way Home Automation Engine main executable ***************************** ...
[2016-10-04 00:06:37.325] [I] [core] Executing script: // Comon utilities and functions ...
[2016-10-04 00:06:37.337] [I] [core] Executing script: // This script transforms old formats to new ...
[2016-10-04 00:06:37.432] [I] [core] Executing script: /*! ...
[2016-10-04 00:06:37.506] [I] [core] Executing script: //     Underscore.js 1.7.0 ...
[2016-10-04 00:06:37.595] [I] [core] Executing script: /*! ...
[2016-10-04 00:06:37.623] [I] [core] Executing script: /*** Z-Way HA Virtual Device base class *************************************** ...
[2016-10-04 00:06:37.631] [I] [core] Executing script: /*** Z-Way DevicesCollection class ************************************ ...
[2016-10-04 00:06:37.683] [I] [core] Executing script: /*** Z-Way HA Controller class module ***************************************** ...
[2016-10-04 00:06:37.699] [I] [core] Executing script: /*** Automation Webserver Auth Controller ************************************* ...
[2016-10-04 00:06:37.702] [I] [core] Executing script: /*** Z-Way HA Automation module base class ************************************ ...
[2016-10-04 00:06:37.705] [I] [core] Executing script:  ...
[2016-10-04 00:06:37.730] [E] [core] result: Error: Error: Failed to bind to 8083
    at Error (native)
    at automation/Webserver.js:4:6
    at automation/main.js:72:5
[2016-10-04 00:06:37.734] [E] [core] result: Error: Error: Uncaught Error: Failed to bind to 8083
    at Error (native)
gsaw
Re: Razberry + BananaPi + Jeedom problem
Post by gsaw »
If you installed a new version of z-way, you dont have z-way-ha/ path anymore.
See you have logged in as admin. Then click on gear-Icon in top right corner. Open "Apps" -> "Active Apps" and then search for "Z-Wave Network Access" module and click on gear icon. There you can setup port for razberry device. I had to write "/dev/ttyS3" for my banana pro.
