GPIO inputs without pullup (HiZ) problem
g-knight
Post by g-knight »
I need to use Hi impedance digital inputs. I connected the input pin through a resistor divider using 100 K / 150 K. My input before the divider varies from 0 to 4.9 V. So output is expected to be between 0 & 2.95 V.
I used the following code:
#define PIR_PIN     9
pinMode(PIR_PIN, INPUT);
pirState = digitalRead(PIR_PIN);
Unfortunately, this always report logical one value.
I measured with a multi-meter, and noticed that voltage on Z-Uno pin doesn't follow the divider output and seems to be constrained as if an internal pull-up were still enabled despite the "INPUT" used, and NOT "INPUT_PULLUP".
I also tried with an analog input pin 6 / ADC3, but it's the same.
A work around I found is using the analog way:
int val = analogRead(A3);
if (val > 500)
  pirState = HIGH;
else
  pirState = LOW;
Is there a bug in the pinMode library?
Gerard
A.Harrenberg
Re: GPIO inputs without pullup (HiZ) problem
Post by A.Harrenberg »
if you disconnect the divider from the Z-Uno and measure again, is the voltage 0 and 2.95V as expected?
The 100/150 kOhm seems also a little high, you might want to try lower values, but that depends also on the what source is connected to the divider.
Andreas.
g-knight
Post by g-knight »
Yes, if I disconnect the divider, I have around 0 and 2.95V as expected.
I don't think 100/150 K is so much, given the documentation:
"Pins configured as INPUT make extremely small demands on the circuit that they are sampling, equivalent to a series resistor of 100 MΩ in front of the pin. This makes them useful for reading a sensor."
I'm wondering if there isn't a bug in the low level firmware that manages the GPIO in the SOC.
But, it's strange that it's not been discovered before... So, did I do something wrong?
Gerard
The chip need some current to detect the voltage. Usually it is about 10 μA as stated here: http://z-uno.z-wave.me/technical/
10 μA at 3 V gives 300 kΩ - this is the limit for Z-Uno to detect correctly input voltage. 100-150 kΩ should still be ok.
Please chekc other pins too (not 9-16). May be there is a problem with 9-16 (they are a bit different from others)
g-knight
Post by g-knight »
I tried with pin 22 and it doesn't work better. Looks the same...
After having programmed
#define PIR_PIN     22
I measured voltage with the pin left unconnected. I got about 3V (so, not floating), and if connect it to ground with ampere meter, it draws 64 µA. More than 6 times from what is written at http://z-uno.z-wave.me/technical/ and far from the 100 MΩ found in doc (https://z-uno.z-wave.me/Reference/INPUT/).
Sure the PULLUP is de-activated?
Gerard
Can you try with 47 kΩ? We took these data from the doc of the chip, have not measured it in more details.
are you sure your sensor have low output resistance? If it is an MCU (like PIR sensor), it's output R is about 100k itself. In that case use a dividor with arms 2k/1k. Looks like there is not enough current for Z-Uno to detect it.
g-knight
Post by g-knight »
No I can't use lower resistances, I really need high impedance.
For the PIR, I don't use something based on a microcontroller, it's a standard flood projector with discrete components, and I don't want to disturb its internal logic.
I'm pretty sure that's the pull-up is still enabled in the chip when using the "INPUT" parameter. Can't you check that point?
As I noticed the same behavior with ADCx inputs, I guess that sooner or later there will be troubles with measuring analog value having high impedance output.
Thank you.
Gerard
g-knight
Post by g-knight »
Hi PoltoS,
Is there any chance that someone in the Z-Uno project team at Z-Wave.Me has a look into this topic?
The value I measured shows an internal impedance of approximately 50 K Ohms, which is typical from microcontrollers' internal pull-up nowadays.
To solve this problem, I changed my circuit and added an op amp in front of the Z-Uno (a LM 324), but in my opinion it's a waste since if the pull up could be removed, the chipset is most probably having MOS inputs with high impedance.
I tried to find datasheet for Mitsumi WML-C85 or Sigma Designs ZM5101 (which the Mitsumi WML-C85 seems to be a second source), but without success. It seems that this part is closed source (I mean manufacturers aren't willing to share information).
Gerard
p0lyg0n1
Post by p0lyg0n1 »
Hi, Gerard. I try it and will post results here. The normal value of pull-up have to be about 20 KOhms.
