RESOLVED: SCALE_LUX results in percentage display
ftrueck
Post by ftrueck »
I've setup a channel for luminance (BH1750):
  ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_LUMINANCE,
                          SENSOR_MULTILEVEL_SCALE_LUX,
                          SENSOR_MULTILEVEL_PRECISION_ZERO_DECIMALS,
                          getterLight)
It results in a sensor device with percentage scale on razberry web ui:
What went wrong? I've used the example provided for BH1750 and this is what I get.
Could someone point me in the right direction?
Regards,
Florian
A.Harrenberg
Re: SENSOR_MULTILEVEL_SCALE_LUX results in percentage displa
Post by A.Harrenberg »
this seems to be an issue in the RazBerry system...
According the header file from the Z-Uno the scale is defined as 0x01
#define SENSOR_MULTILEVEL_SCALE_LUX		0x01
And that is what is defined also in the ZWave-specification (SDS12657-12-Z-Wave-Command-Class-Specification-A-M.pdf, page 508). So if there is no very wierd bug in the zuno-code I would point that toward the RazBerry (Z-Way)...
Regards,
Andreas.
michap
Post by michap »
With OpenZwave it is working fine.
Are you using latest Z-Uno firmware and Z-Way version?
Michael
I remeber we have fixed wrong scales in Z-Way recently. What version are you using?
ftrueck
Post by ftrueck »
My current razberry version is 2.2.3
Z-Uno version is 2.0.6
I was not sure if it is a bug in razberry, because I have fibaro multi sensor which reports also light in lux which is correctly displayed in UI.
Please show the log line with RECIEVED that comes from Z-Uno with the luminance settings
michap
Post by michap »
Just have tested with Z-Way installation 2.2.3 and Z-Uno 2.0.6.
it is working as expected - I see the lux values.
Maybe you have used the Z-Uno before with other sketch - and forgot to exclude the Z-Uno before use new sketch / function?
If you overwrite the sketch without excluding the Z-Uno (if you are changing the device definition) - it can give similar effects.
Please try to exclude the device - and then include it again.
Michael
ftrueck
Post by ftrueck »
WOW! Cool! Thanks for the hint with reincluding. That helped. :-)
