Sensative Strip stopped working in 2.2.4-rc16
Mansica
Post by Mansica »
I have installed 2.2.4-rc16 to get support for qubino relay switches. Please see post viewtopic.php?f=3422&t=23717
The problem now is that the device that was working ok before upgrading is now broken. It is a Sensative strip sensor. http://www.sensative.com
The device used to have three features. Now it just got the general purpose, completely useless feature.
I found this post viewtopic.php?f=3422&t=23864 so I installed rc17 with no success.
So, whats up with door sensors and the latest 2.2.4?
Re: Sensative Strip stopped working in 2.2.4-rc16
Your problem may be caused because of the postfix mechanism. During upgrade to an new version some virtual devices (features as you say) automagically disappear. Unfortunately without war ning to the user, and that is really bad!
It happened with my Popp smoke sensors, and also with the two Sensative strips I have.
The strips do work for me with this setting of the first parameter:
Hope this works for you
Mansica
Post by Mansica »
I'm not able to set any parameters on my sensitive strip: Battery device must be woken up to activate changed settings.
However, I re-included the device in 2.2.4 and now it is "working" again. With the exception that it is now the general purpose feature triggering when the door is opened. The problem is that I'm using homebridge-zway and that is not registering the general purpose feature but the door feature and that feature is not triggered anymore.
