Zooz Z-Wave Plus MiniPlug
CudaNet
Post by CudaNet »
I just received this new product and was able to interview the device but it required a bit of a nudge for almost all classes. The issue I'm encountering has to do with the reporting of energy use.
I'm not sure what's needed so I'll post what I can here.
Manual outlining Command Classes.
https://cdn.shopify.com/s/files/1/0218/ ... 4239741723
COMMAND_CLASS_ZWAVEPLUS_INFO (V2)
COMMAND_CLASS_MANUFACTURER_SPECIFIC (V2)
COMMAND_CLASS_VERSION (V2)
COMMAND_CLASS_ASSOCIATION (V2)
COMMAND_CLASS_ASSOCIATION_GRP_INFO (V1)
COMMAND_CLASS_DEVICE_RESET_LOCALLY (V1)
COMMAND_CLASS_POWERLEVEL (V1)
COMMAND_CLASS_SWITCH_BINARY (V1)
COMMAND_CLASS_NOTIFICATION (V4)
NOTIFICATION_REPORT
NOTIFICATION_TYPE_POWER_MANAGEMENT
NOTIFICATION_EVENT_POWER_MANAGEMENT_OVER_CURRENT_DETECTED
NOTIFICATION_EVENT_POWER_MANAGEMENT_NO_EVENT
COMMAND_CLASS_METER (V4)
COMMAND_CLASS_CONFIGURATION (V1)
COMMAND_CLASS_SWITCH_ALL (V1)
COMMAND_CLASS_BASIC (V1)
Interview Result (expert):
0  	Basic
/: None (19.10.2016)
    supported: true (19.10.2016)
    version: 1 (19.10.2016)
    security: false (19.10.2016)
    interviewDone: true (19.10.2016)
    interviewCounter: 9 (19.10.2016)
    level: 255 (19.10.2016)
0  	SwitchBinary
    level: false (08:47)
0  	SwitchAll
    mode: 0 (19.10.2016)
    onOff: None (19.10.2016)
0  	Meter
    0: None (12:20)
        sensorType: 1 (19.10.2016)
        sensorTypeString: Electric (19.10.2016)
        val: 0.12 (12:20)
        scale: 0 (19.10.2016)
        scaleString: kWh (19.10.2016)
        ratetype: 1 (12:20)
        delta: 0 (12:20)
        previous: 0.12 (12:20)
    2: None (12:10)
        val: 0 (12:10)
        scale: 2 (19.10.2016)
        scaleString: W (19.10.2016)
        ratetype: 1 (12:10)
        delta: 0 (12:10)
        previous: 0 (12:10)
    4: None (11:50)
        val: 0 (11:50)
        scale: 4 (19.10.2016)
        scaleString: V (19.10.2016)
        ratetype: 1 (11:50)
        delta: 0 (11:50)
        previous: 0 (11:50)
    5: None (12:10)
        val: 0 (12:10)
        scale: 5 (19.10.2016)
        scaleString: A (19.10.2016)
        ratetype: 1 (12:10)
        delta: 0 (12:10)
        previous: 0 (12:10)
    version: 4 (19.10.2016)
    resettable: true (19.10.2016)
    scalemask: 53 (19.10.2016)
0  	AssociationGroupInformation
: None (19.10.2016)
    1: None (19.10.2016)
        groupName: Lifeline (19.10.2016)
        profile: 1 (19.10.2016)
        eventCode: 0 (19.10.2016)
        commands: None (19.10.2016)
            37: 3 (19.10.2016)
            50: 2 (19.10.2016)
            90: 1 (19.10.2016)
            113: 5 (19.10.2016)
    2: None (19.10.2016)
        groupName: Basic Set Rep. (19.10.2016)
        profile: 28936 (19.10.2016)
            32: 1 (19.10.2016)
    3: None (19.10.2016)
        groupName: Power Alarm Rep. (19.10.2016)
            113: 5 (19.10.2016)
    interviewCounter: 8 (19.10.2016)
    dynamic: false (19.10.2016)
0  	DeviceResetLocally
    reset: false (19.10.2016)
0  	ZWavePlusInfo
    version: 2 (19.10.2016)
    plusVersion: 1 (19.10.2016)
    roleType: 5 (19.10.2016)
    nodeType: 0 (19.10.2016)
    installerIcon: 1792 (19.10.2016)
    userIcon: 1792 (19.10.2016)
    roleTypeString: Always On Slave (19.10.2016)
0  	Configuration
0  	Alarm
    8: None (10:10)
        typeString: Power Management (19.10.2016)
        status: 255 (10:10)
        eventMask: 256 (19.10.2016)
        event: 0 (10:10)
        eventString: (10:10)
        eventParameters: (10:10)
        eventSequence: None (09:00)
    V1supported: false (19.10.2016)
    typeMask: 256 (19.10.2016)
    V1event: None (19.10.2016)
        alarmType: None (19.10.2016)
        level: None (19.10.2016)
0  	ManufacturerSpecific
None (19.10.2016)
    vendorId: 634 (19.10.2016)
    vendor: (19.10.2016)
    productId: 135 (19.10.2016)
    productType: 3 (19.10.2016)
    serialNumber: 255,120,1,2,3,4,5,6 (19.10.2016)
0  	PowerLevel
 None (19.10.2016)
    level: 0 (19.10.2016)
    timeout: 0 (19.10.2016)
0  	Association
None (19.10.2016)
        max: 5 (19.10.2016)
        nodes: 1 (19.10.2016)
        max: 5 (19.10.2016)
        nodes: (19.10.2016)
        max: 5 (19.10.2016)
        nodes: (19.10.2016)
    groups: 3 (19.10.2016)
    specificGroup: None (19.10.2016)
0  	Version
None (19.10.2016)
    ZWLib: 3 (19.10.2016)
    ZWProtocolMajor: 4 (19.10.2016)
    ZWProtocolMinor: 5 (19.10.2016)
    SDK: 6.51.06 (19.10.2016)
    applicationMajor: 3 (19.10.2016)
    applicationMinor: 81 (19.10.2016)
    hardwareVersion: 65 (19.10.2016)
    firmwareCount: 0 (19.10.2016)
CudaNet
Re: Zooz Z-Wave Plus MiniPlug
Post by CudaNet »
Gathering z-way-server log data just in case..
14kb zipped file...
zooz_Interview.zip
Zooz Interview
(13.7 KiB) Downloaded 534 times
CudaNet
Post by CudaNet »
After installing a Gen2 Razberry board on a new Pi3 running 2.2.3, I was able to successfully include the Zooz mini plug (1st try) and I'm happy to report it's showing a full energy report. Not sure why I had multiple failed interviews (had to force it each and every time) on the Gen1 but nonetheless - I'm glad as this is a pretty neat little plug.
