Razberry2 can not log in to UI
Happykid73
Post by Happykid73 »
Hi
I am new to rasberry and the Z-wave world.
I have the following hardware... Razberry3 and Razberry2.
When i type http://10.x.x.x.xx:8083 i get this script.. can any one help tell me what i do wrong.
<!doctype html>
<html lang="en" ng-app="myApp" ng-controller="BaseController">
<head>
<meta charset="utf-8">
<title>Z-Wave Smart Home</title>
<meta http-equiv="X-UA-Compatible" content="IE=edge,chrome=1" />
<meta name="viewport" content="width=device-width, initial-scale=1.0" />
<!-- CSS -->
<link id="main_css" media="screen" type="text/css" rel="stylesheet" href="app/css/main.css">
<!-- App config -->
<script src="app/js/config.js"></script>
<!-- JS -->
<script src="app/js/build.js"></script>
</head>
<body id="page_{{getBodyId()}}" class="app-type-{{cfg.app_type}} is-mobile-{{isMobile}} os-{{cfg.route.os}} profile-{{user.color.substring(1)}}">
<a class="skinreset" href="#skinreset">Reset skin to default</a>
<div id="header" ng-if="user">
<div id="main_navigation_wrap">
<div id="main_navigation" class="container">
<div id="navigation_left">
<a class="nav-logo" href="#home" title="{{_t('nav_home')}}">
<img ng-src="{{getAppLogo()}}" id="header_logo" alt="App logo" />
</a>
<span class="divider-vertical"></span>
<a href="#home" title="{{_t('nav_home')}}" ng-class="isActive('dashboard')"><i class="fa fa-home"></i></a>
<a href="#rooms" title="{{_t('nav_rooms')}}" ng-class="isActive('rooms')" ng-if="elementAccess(cfg.role_access.rooms)"><i class="fa fa-building-o"></i></a>
<a href="#elements" title="{{_t('nav_elements')}}" ng-class="isActive('elements')"><i class="fa fa-clone"></i></a>
<a href="#events" title="{{_t('nav_events')}}" ng-class="isActive('events')"><i class="fa fa-calendar"></i></a>
&nbsp;<span class="timestamp clickable" ng-click="reloadData()" ng-if="cfg.route.time.string"><i class="fa fa-clock-o"></i> {{cfg.route.time.string}}</span>
</div>
<div id="navigation_right">
<a id="navi_settings" href="" title="{{_t('lb_configuration')}}" ng-click="expandNavi('mainNav', $event)" ng-class="naviExpanded.mainNav ? 'active' : ''"><i class="fa fa-cog"></i></a>
</div>
</div><!-- /#navigation -->
</div><!-- /#main_navigation_wrap -->
<div id="sub_navigation" ng-if="naviExpanded.mainNav">
<div id="sub_navigation_in">
<div class="container">
<ul>
<!-- Apps -->
<li class="subnavi-apps" ng-class="isActive('apps')" ng-if="elementAccess(cfg.role_access.apps)">
<a href="#apps/local"><i class="fa fa-cubes"></i> <span>{{_t('nav_apps')}}</span> <i class="fa fa-chevron-right subnavi-arrow"></i></a>
</li>
<!-- Devices -->
<li class="subnavi-devices" ng-class="isActive('devices')" ng-if="elementAccess(cfg.role_access.devices)">
<a href="#devices"><i class="fa fa-cogs"></i> <span>{{_t('nav_devices')}} </span> <i class="fa fa-chevron-right subnavi-arrow"></i></a>
</li>
<!-- Config rooms -->
<li class="subnavi-config-rooms" ng-class="isActive('config-rooms')" ng-if="elementAccess(cfg.role_access.config_rooms)">
<a href="#config-rooms"><i class="fa fa-building-o"></i> <span>{{_t('nav_rooms')}}</span> <i class="fa fa-chevron-right subnavi-arrow"></i></a>
</li>
<!-- Customize -->
<!--<li class="subnavi-report" ng-class="isActive('customize')"
ng-if="elementAccess(cfg.role_access.customize) && !isInArray(['popp','jb'],cfg.app_type)">
<a href="#customize/skinslocal"><i class="fa fa-puzzle-piece"></i> <span>{{_t('customize')}}</span> <i class="fa fa-chevron-right subnavi-arrow"></i></a>
</li>-->
<!-- My access -->
<li class="subnavi-myaccess" ng-class="isActive('myaccess')" ng-if="elementAccess(cfg.role_access.myaccess)">
<a href="#myaccess"><i class="fa fa-user"></i> <span>{{_t('nav_myaccess')}}</span><i class="fa fa-chevron-right subnavi-arrow"></i></a>
</li>
<!-- Management -->
<li class="subnavi-admin" ng-class="isActive('admin')" ng-if="elementAccess(cfg.role_access.admin)">
<a href="#admin"><i class="fa fa-wrench"></i> <span>{{_t('management')}}</span> <i class="fa fa-chevron-right subnavi-arrow"></i></a>
</li>
<!-- Logout -->
<li class="subnavi-logout" ng-if="elementAccess(null, isMobile)">
<a href="#logout"><i class="fa fa-sign-out"></i> <span>{{_t('nav_logout')}}</span> <i class="fa fa-chevron-right subnavi-arrow"></i></a>
</li>
</ul>
</div>
</div><!-- /#subnavigation_in -->
</div><!-- /#subnavigation -->
</div><!-- /#header -->
<!-- Ang Content Container -->
<div id="main_content" class="container">
<div ng-if="cfg.route.fatalError.message">
<div class="app-fatal-error">
<div class="fatal-error-message"><i class="fa {{cfg.route.fatalError.icon}} fa-lg"></i> {{cfg.route.fatalError.message}}</div>
<div class="fatal-error-info" ng-if="cfg.route.fatalError.info" ng-bind-html="cfg.route.fatalError.info|toTrusted"></div>
</div>
</div>
<div id="view_content" ng-hide="cfg.route.fatalError.hide" ng-view></div>
</div>
<div class="clearfix"></div>
<div id="footer">
<div id="footer_in">
</div>
</div>
</div>
</body>
</html>
Re: Razberry2 can not log in to UI
What browser do you use? Try Chrome or Firefox
Happykid73
Hi Thanks for you quick answer.. I use the default browser on the Rasbian UI.. I will try using another browser.
AlesKO
Post by AlesKO »
Same problem I had few days ago (https://forum.z-wave.me/viewtopic.php?f=3422&t=24110).
And nobody there to have an answer.
Looks like it is some version/compatibility issue. My solution was:
1. Downloaded latest NOOBS version from https://www.raspberrypi.org/downloads/noobs/ and installed it with Raspbian OS
2. Installed latest z-wave software: wget -q -O - razberry.z-wave.me/install | sudo bash
3. Using Chromium browser (default one) typed: find.z-wave.me. Login window appeared.
4. Clicked on RP3 IP address and 'bingo' problems are gone.
It must really be some stupid version issue and unfortunatelly no expert support on this forum.
