Surveillance cam
alphons
Surveillance cam
Post by alphons »
Hello
I have a HikVision IP-camera and are trying to get the stream implemented in the zway server.
I see that the server isn`t supporting rtsp streams at this point, so I have tried getting picture with the general web cam module.
I have got a http-stream with Mjpeg by following this guide:
http://bkeesti.ee/upload/Hikvision/HowT ... ublic).pdf
But I can`t get picture in the Z-way server with this one. Isn`t the web cam module supporting MJPEG, or is there another reason that it will not show the picture?
Re: Surveillance cam
Mjpeg is supported
alphons
Post by alphons »
OKAY, good.
Do you have any idea why it doesn`t work?
When useing this link, i get the mjpeg-stream in my browsers:
http://username:passord@ip/Streaming/ch ... ttppreview
But i can`t get the picture in Zway.
Have tried with and without the password directly in the Camera URL.
Is the Web Cam app working with remote resources, so that I need port openings in my firewall?
Please check borwser network log and browser console to see the problem
bogr
Post by bogr »
alphons wrote: Is the Web Cam app working with remote resources...
Is the app named "Web Cam"? Where did you find it, I can't find it in "Local apps" or "Online apps"? Or is this new and only exists in in 2.2.4?
Cheers.
alphons
Post by alphons »
bogr
The app is integratet in the Zway server interface.You can find it under Devices-> Add new ("camera")->Web camera
alphons
Post by alphons »
bogr
Post by bogr »
Aaah, now I get it. Thanx a lot :D
How have you configured your camera app in Z-Way? Have you entered login and password in correct fields, not in url?
alphons
Post by alphons »
I have tried both.
The log I pasted is when I use username and password in the URL.
http://****:*****@10.0.0.136/Streaming/ ... ttppreview
