Z-Way Fahrenheit config Defaults setting
vlad
Post by vlad »
I set Fahrenheit field to "1" in Defaults and forced interview on sensor ( Vision PIR with Temperature).
I get correct reading in Z-Way UI but with Celsius label, like this 78C... should be 78F.
How can I fix it?
Z-Wave Support
Re: Z-Way Fahrenheit config Defaults setting
Post by Z-Wave Support »
we have tested the device.
It cannot transmit the unit of the Temperature.
The default unit for temperature is °C.
Z-Wave Support Team
vlad
Post by vlad »
Yes, I have tried both ways, when I set Vision PIR sensor to transmit in Fahrenheit - sensor just ignore it and send value in Celsius. So, in ZWay UI I have 25C as a temperature.
If I set Fahrenheit field in /opt/z-way-server/config/Defaults.xml file to "1" - the z-way-server will convert C into F internally by using formula ( C * 1.8 + 32 ) so UI will show number 77 BUT the label after that number is still char 'C' not the char 'F'.
So, how can I fix that "cosmetic" issue?
Z-Wave Support
please restart your Z-Way System.
Exclude your PIR Device and include it again.
Then you have the Temperatur in Fahrenheit.
Z-Wave Support Team
Z-Way 2.2.4
Z-Way 2.2.4
Default.xml
Default.xml
vlad
Post by vlad »
Yes, that did the trick.
Previously, I just did forced re-interview and that did not update char "C" into "F".
