Unknown error
A.Harrenberg
Unknown error
Post by A.Harrenberg »
I am trying to convert an Arduino library to the ZUNO, I have cleared a lot of error messages from the compiler but I am stuck... The compiler is throwing an "Unknown error":
ZUNO_MFRC522_sdcpp_.cpp:2404:18:warning:conversion from string literal to 'char *' is deprecated
ZUNO_MFRC522_sdcpp_.cpp:2418:17:warning:conversion from string literal to 'char *' is deprecated
ZUNO_MFRC522_sdcpp_.cpp:2421:19:warning:conversion from string literal to 'char *' is deprecated
ZUNO_MFRC522_sdcpp_.cpp:2443:19:warning:conversion from string literal to 'char *' is deprecated
ZUNO_MFRC522_sdcpp_.cpp:2453:17:warning:conversion from string literal to 'char *' is deprecated
ZUNO_MFRC522_sdcpp_.cpp:2480:17:warning:conversion from string literal to 'char *' is deprecatedUnknown error:'enum MFRC522::StatusCode' uCxx returned error code:-1
Fehler beim Kompilieren.
The error message apprears without a newline direct after the last warning and is not preceeded by the filename, line-number... I have already enabled all compiler warnings and the extended reporting during compilation but there is no more information available.
Is there a way to find out what is causing this error?? There is no "enum MFRC522::StatusCode" in the code, only the below enumeration from the header file, so I guess it is something that the compiler creates when he is e.g. evaluating the constructor...
In the orignial code there was this enumeration with a forward reference to "byte", which is not allowed in C++, so I just removed the type defintion:
	//enum StatusCode : byte {
	enum StatusCode {
		STATUS_OK							,	// Success
		STATUS_ERROR					,	// Error in communication
		STATUS_COLLISION			,	// Collission detected
		STATUS_TIMEOUT				,	// Timeout in communication.
		STATUS_NO_ROOM				,	// A buffer is not big enough.
		STATUS_INTERNAL_ERROR	,	// Internal error in the code. Should not happen ;-)
		STATUS_INVALID				,	// Invalid argument.
		STATUS_CRC_WRONG			,	// The CRC_A does not match
		STATUS_MIFARE_NACK		= 0xff	// A MIFARE PICC responded with NAK.
There are several functions in the code which use StatusCode as their typedef. It is quite a long time ago that I programmed in C and I have not much experience in C++ at all, so I don't know if that is causing the problem or not...
Any hints are welcome here.
Thank you very much in advance,
Andreas.
p0lyg0n1
Re: Unknown error
Post by p0lyg0n1 »
Try to use byte/int instead of StatusCode type in the function parameters
A.Harrenberg
Re: Unknown error
I tried that with byte before and run into a lot of other errors...
There were a lot of errors where it seems that StautusCode was not using byte, as there error messages complained about that byte is not the correct datatype. I will try to make some test code first to see if the enum is using byte or int.
Then I will change the functions to the used type and try to work on the new error messages.
The compiler option is already set to --verbose
compiler.sdccOptions = '-mmcs51 --out-fmt-ihx --model-large --verbose --debug --use-stdout --code-loc 0x8000 --xram-loc 0x3000'
, so I guess the compiler error can not be tracked... ,-(
Regards,
Andreas.
Re: Unknown error
Can you share the code so we can look on it?
A.Harrenberg
Re: Unknown error
PoltoS wrote:Can you share the code so we can look on it?
I attached the library code and an example code. I removed the doc and other examples from the library to save some space. It is the "standard" MFRC522 from the Arduino.
Regards,
Andreas.
ZUNO_MFRC522.zip
MFRC522 libraray
(34.98 KiB) Downloaded 536 times
ZUNO_DumpInfo_MFRC522.zip
Example code
(1.68 KiB) Downloaded 501 times
A.Harrenberg
Re: Unknown error
I just created some sample code to find out what size an enum has with this compiler and in my case it is using 2byte = int, so I will try to change the all the reference to the enumeration to int...
I will be busy on the during the next days, so I might not answer until next week.
Regards,
Andreas.
p0lyg0n1
Re: Unknown error
Post by p0lyg0n1 »
Hi, I just have the first "quick look" to your code.
And I have some recipes for you:
1. You have to define SS pin number. Z-Uno can use any IO pin for this.
Compiler said about it:
Compiling /Users/alexander/Code/ZUno/compilerCXX/tests/Tests_Builds/MFRC522/ZUNO_MFRC522_sdcpp_.cpp ...
ZUNO_MFRC522_sdcpp_.cpp:827:23:error:use of undeclared identifier 'SS'
ZUNO_MFRC522_sdcpp_.cpp:1025:11:error:use of undeclared identifier 'SS'
2. Move all enums/structs outside the class-space. We use simplified C++ that called uC++ and it doesn't support embedded enums/structs/classes inside another class.
3. Replace all "StatusCode" in the names of function to "byte". For example:
StatusCode PCD_TransceiveData(byte *sendData, byte sendLen, byte *backData, byte *backLen, byte *validBits = NULL, byte rxAlign = 0, bool checkCRC = false);
will be:
byte PCD_TransceiveData(byte *sendData, byte sendLen, byte *backData, byte *backLen, byte *validBits = NULL, byte rxAlign = 0, bool checkCRC = false);
4. uCxx doesn't support static const fields inside class like this:
static const byte FIFO_SIZE = 64;
Just use macro-style (
#define FIFO_SIZE 64
We will try to make a list of deprecated C++ techniques for the next release.
A.Harrenberg
Re: Unknown error
Hi p0lyg0n1,
thank you very much for all the hints!
p0lyg0n1 wrote: 3. Replace all "StatusCode" in the names of function to "byte". For example:
will be:
As this is used in the context of the enumeration and the enumeration uses int, I guess I should then also use int for the function??
The compiler does not optimize the size for the enum to byte, even if the last element is defined as 0xff.
p0lyg0n1 wrote: We will try to make a list of deprecated C++ techniques for the next release.
Yes, I think a list will be very helpfull for all developments...
Regards,
Andreas.
A.Harrenberg
Re: Unknown error
Hi p0lyg0n1,
p0lyg0n1 wrote: 1. You have to define SS pin number. Z-Uno can use any IO pin for this.
This was defined in my system, I added it in ZUNO_Definitions.h but forgot to give it to you. I moved the definition now to ZUNO_MFRC522.h
I did this now in several variations... First I tried with byte, there were a lot error saying that the enum can't be assign with a type of byte. Tried it with int, same result. The last two attempts with using StatusCode or using byte and casts to StatusCode for the assignments both end with another "unknown error"... :(
Compiling C:\Users\andre\AppData\Local\Temp\build152256629544549265.tmp\ZUNO_MFRC522_sdcpp_.cpp ...Unknown error:list index out of range uCxx returned error code:-1
So I am back at square one, it seems that there is still some problem with the enumerations... But what is the problem and where...
Regards,
Andreas.
p0lyg0n1
Re: Unknown error
Post by p0lyg0n1 »
Hi, Andreas.
Please post the one of them. I need a whole source to understand this.
