Problem with the hour
jordiporcel
Post by jordiporcel »
Razpberry
Firmware version V.2.2.4
UI version 1.5.
The time for the razpberry is correct.
But,
I have an hour less.
I've read that, That the solution is here
enter http://[IPOFYOURRASP]:8084 go to Advanced > System > Timezone.
But, when enter http://[IPOFYOURRASP]:8084,
ERROR -"Webif is switched off. You can switch it on from Z-Way UI or box shell"
After,
To solve this error, I read that you have to go to "Manage With ExpertUI".
inside of the "Manage With ExpertUI", I have not found a solution.
Tnks
