Javascript sample for a newbie
Provo
Re: Javascript sample for a newbie
Post by Provo »
You are creating a function expression and assigning it to this.bindFunc1, but you are never actually running the function. If you look at the recipe, you will see that after the function expression is defined, there is also the following code:
// process all active bindings
if (global.ZWave) {
   global.ZWave().forEach(this.bindFunc1);
This runs the function expression with every element in the result from global.ZWave() as the argument to the function. So if gobal.ZWave() returns an array of the three strings "blah", "blahblah" and "zway", your function will be run three times: one with "blah" passed as the argument, one with "blahblah" passed as the argument, and one with "zway" as the argument.
The name "bindFunc1" is pretty arbitrary and could have been anything, but the author presumably called it "bindFunc1" because what it does is creating new small functions that it is binding to certain changes in certain devices (meaning these small functions will be run when these kind of changes occur). Unless you're doing anything like that, I suggest you pick a more descriptive name. :)
AMal
Post by AMal »
Provo wrote:You are creating a function expression and assigning it to this.bindFunc1, but you are never actually running the function. If you look at the recipe, you will see that after the function expression is defined, there is also the following code:
if (global.ZWave) {
Thanks, provo.
But I'm still confused.
I have changed my code to add your suggestion as follows:
console.log("Starting");
this.bindFunc1=function(zwayName)
  if (zwayName!="zway"){console.log("name failure");return;}
  var devices=global.ZWave[zwayName].zway.devices;
  console.log("name found and devices array set");
if (global.ZWave) {
   console.log("global.ZWave=true");
}else{console.log("global.ZWave=false");}
The result is the boolean global.ZWave is false.
Clearly I am missing something fundamental.
I have searched this forum, but without success.
I did notice in one post the comment:
"Note that global zway object may change or disappear, so your module should be ready to handle that."
This seems rather worrying!
It might be worth restating that I am trying to create (at first) a minimal server-side JS program to list the elements in the network, and the methods and properties of each object.
Thanks for your patients.
Provo
Post by Provo »
Ok, I just noticed that you said that you're running the script from /opt/z-way-server with node. That will not work. Then you're just running your file alone, and there is no global.ZWave() defined there. As the recipe says, put your script in /opt/z-way-server/automation/storage, and I assume it will be run by the Z-Way system when you restart it. (I'm not exactly sure where console.log() will output, but I guess it's in the z-way log.)
(By the way, it's much easier to read your code if you use code-tags around it. That way indentation is preserved. Use it like this: [ code ]your code here[ /code ]. Just remove the spaces within the square brackets to make it work.)
Provo wrote:Ok, I just noticed that you said that you're running the script from /opt/z-way-server with node. That will not work. Then you're just running your file alone, and there is no global.ZWave() defined there. As the recipe says, put your script in /opt/z-way-server/automation/storage, and I assume it will be run by the Z-Way system when you restart it.
Placing the JS code in that directory does not make it start. According to the recipe you have to use the JS App to get it started:
IIRC if you make changes to your script you can just stop the JS script by pressing on the little flame as shown at the very right of the image above. (and start it again there)
It does indeed go to /var/log/z-way-server.log
In my role as moderator I had taken the liberty of adding those quotes earlier today.
AMal
Post by AMal »
I seem to be getting nowhere with this.
I am running from a terminal session on the Pi server - no GUI.
As suggested, I have put my code into /opt/z-way-server/automation/storage, but if I execute it there with
sudo node bind.js
I get the same result: The boolean global.ZWave is false.
If, rather than use nodeJS I try to execute the command JS as suggested, I get "JS: command not found".
I've tried restarting the Pi, and I've looked in z-way-server.log, but find no clues.
I have re-read the Z-Way Developers' Documentation, which indeed contains a lot of potentially useful information, but I am still clueless on how to get started.
Provo
Post by Provo »
You can't run your script from the terminal. You have to use the Z-Way module/app for executing JS scripts inside the Z-Way environment.
If you want something that can be run from the terminal, you need to change your strategy. Like making http requests to your Z-Way server and using one of the APIs described in the developers manual: https://razberry.z-wave.me/docs/zway.pdf
AMal
Post by AMal »
Provo wrote: Quote 1:Placing the JS code in that directory does not make it start. According to the recipe you have to use the JS App to get it started:
Quote 2: You can't run your script from the terminal. You have to use the Z-Way module/app for executing JS scripts inside the Z-Way environment.
OK, thanks.
Can you point me to a step by step process to add my script to the Z-Way environment and how to "use the Z-Way module/app for executing JS scripts inside the Z-Way environment."
Quote 1 refers to the JS App. Where is that, and how do I run it?
I want to avoid, if possible, running from a browser.
Cheers.
Provo
Post by Provo »
You log into your Z-Way web interface. Then you click the cog in the upper right corner, and go to "Apps". Then click the "Online Apps" button. There you have a button which probably says "Featured apps". Click it and change to "Developers Stuff". There you have an app called "Load custom JavaScript file", most likely abbreviated in the overview to "Load custom JavaScript …". Install, add app, and set it up with the path to your file.
AMal
Post by AMal »
Provo wrote:You log into your Z-Way web interface. Then you click the cog in the upper right corner, and go to "Apps". Then click the "Online Apps" button. There you have a button which probably says "Featured apps". Click it and change to "Developers Stuff". There you have an app called "Load custom JavaScript file", most likely abbreviated in the overview to "Load custom JavaScript …". Install, add app, and set it up with the path to your file.
Thank you, that was helpful.
However, I now find that I cannot use the javascript/node directive "require" as in
var fs=require('fs');
I was hoping to use this to read and write files (in particular to write my own log file rather than write to console.log which goes into z-way-server.log.
I also want to require('socket.io') and require('net').
These are all typical server side functions.
Is there any way these can be implemented in z-way?
Also, It seems that JS code added by the "load custom Javascript" process gets executed only at system startup.
Is that correct?
And how/when is the log file emptied? It seem to contain rather a lot for my very simple network.
Yes, Z-Way has fs. and socket. and some other functions. Please check https://github.com/Z-Wave-Me/Z-Way-Manu ... wayDev.pdf
