Razberry + Swtich Fibaro 2x1,5kW Maximum range 2 meters
juliodeburzaco
Post by juliodeburzaco »
Hello good afternoon,
I'm new to the forum, I live in Argentina, I wanted to ask if you can help me ...
Buy a razberry in Spain of 5 generation, install it in my raspberry and it works well,
Buy in the united states a fibaro switch module.
The problem I have is the distance between gateway and fibaro,
I can only connect them two meters away, At three meters loses signal, Can someone tell me why, thank!!
Re: Razberry + Swtich Fibaro 2x1,5kW Maximum range 2 meters
This is because you use EU version of RaZberry and US frequency - your range will be very limited
