Gentlemen, I need some help.
I am starting my smart home backwards. I have this lock, and now I would like to add a z-wave hub to control it, and add a few more accessories: dimmers and camera.
Given that, which hub (to be purchased in the US) should I choose, that works well with this lock, and (i) it is compatible with a variety of dimmers and cameras, as well as (ii) easy to configure and use?
Thank you so much for your help.
Yale YRD210 - which hub?
Re: Yale YRD210 - which hub?
Could someone help me?
You are asking which hub is compatible with your lock without saying which lock it is, which makes it difficult to help you. But in principle, as long as you keep to the right frequency for your area, any Z-Wave hub should work with any Z-Wave device (although occasionally there are some hiccups, as you can see from this forum). You will have to check the product descriptions to find the extent to which they support different types of cameras. I guess they're all pretty easy to configure and use, but I've only tried Z-Way/Razberry so I can't say for sure.
I am sorry if I was not clear. The lock is the one at the topic title: Yale YRD210. Thank you so much for yor reply!
Oh, sorry, I didn't notice you mentioning it in the title. But as I said, if you have the Z-Wave module, any hub should in principle work.
Thank you so much again. And yes, I have the module.
