Disable Razberry 2 reset button
el_fog
Post by el_fog »
Hello!
Is there any way to completely disable reset button on Razberry 2 board? Any hints, info, or links for further reading will be much appreciated.
Z-Wave Support
Re: Disable Razberry 2 reset button
Post by Z-Wave Support »
which Version of Z-Way do you use?
regards
Z-Wave Support
el_fog
Post by el_fog »
Z-Wave Support wrote: which Version of Z-Way do you use?
Firmware
SDK Version: 6.51.03
Serial API Version: 05.00
Software Information
Version number: v2.2.4
Compile-ID: dbad9efdbcae16962cff77f51d025f2db8d96311
Compile-Date: 2016-10-22 02:33:36 +0300
Z-Wave Support
Show here:
viewtopic.php?f=3417&t=23550&p=62939&hi ... Key#p62939
Best regards
Z-Wave Support
freeman
Post by freeman »
I checked and can't find file /etc/init.d/readKey. Maybe you can suggest some other way for disable the reset button on RaZberry 2 board.
Why do you think it is enabled?
