Fibaro RGBW controller question
AlesKO
Post by AlesKO »
Would like my ambient RGB strips to power ON at 19.00 pm and OFF at 24.00 pm. When strips are ON colour/brightness should slowly change over time - automatically (without using I1-I4 switches).
It is easy to change colors/brightness manually using web page, but it is not practical. I need automatic and predefined solution. No manual interaction.
Possible solutions:
1. Setting parameter 72 (starting predefined program). It actually works if set between 6 and 10, but doesn't start automatically when RGB is powered ON using Schedule application. How do I trigger predefined program from within 'Schedule' or some other app.?
2. Other solution would be to write my own 'program' (turn R ON and slowly fade, later turn R OFF and G ON and fade.....), but I would need some Timer application.
Any suggestions?
Z-Wave Support
Re: Fibaro RGBW controller question
Post by Z-Wave Support »
you can create a HTTP device with the commands to set a color.
http://[YOURIP]:8083/ZAutomation/api/v1/devices/[YOURDeviceID]/command/exact?red=000&green=20&blue=255
The HTTP Device canyou use with scenes.
regards
Z-Wave Support Team
Z-Wave Support
if you use Parameter 72. You can make a Http-Device with following command:
http://YOURIP:8083/ZWaveAPI/Run/devices[DeviceID].instances[0].commandClasses[112].Set(72,Parameter1-10,1)
Best regards
Z-Wave Support
