Remote Access limitations, Carrier NAT
ridewithstyle
Post by ridewithstyle »
Hello there,
Are there any limitations regarding the IP the zway server must have?
I want to set up a second razberry system which is connected to the internet via surfstick/router of an ISP. So the router does not have a public IPv4, but instead some IP in changing private ranges. Would the remote access still be possible or is this a deal breaker? Currently I am getting an address in the 100.x.x.x Carrier NAT range, but I have seen different ranges in the past.
Has anyone ever tried remote access with Carrier NAT?
Thanks and best regards
rws
Re: Remote Access limitations, Carrier NAT
no limitations, any NAT is ok. Your Pi just need to be able to access find.z-wave.me on port 22
ridewithstyle
Excellent, thanks for the clarification.
I will setup the system and report on progress the next time, I visit.
Regards,
rws
