SRT321 set point works but emits error messages
pgdharman
Post by pgdharman »
Whether I use the device's widget or the Scheduler app to change the set point on my Secure SRT-321 thermostat, I get "Error during perform command execution: Error: Invalid argument" in the GUI log and messages like these in /var/log/z-way-server.log ...
[2017-01-04 16:17:18.570] [core] --- ZWayVDev_zway_12-0-67-1 performCommand processing: {"0":"exact","1":{"level":"18.5"}}
[2017-01-04 16:17:18.571] [D] [zway] SETDATA devices.12.instances.0.commandClasses.67.data.1.setVal = 18.500000
[2017-01-04 16:17:18.571] [zway] Adding job: ThermostatSetPoint Set
[2017-01-04 16:17:18.571] [zway] Adding job: ThermostatSetPoint Get
[2017-01-04 16:17:18.571] [zway] Node 12:0 CC ThermostatMode: Thermostat Mode 1 is not supported by device (modemask 0x0)
[2017-01-04 16:17:18.579] [core] Notification: error (module): Error during perform command execution: Error: Invalid argument
[2017-01-04 16:17:18.586] [core] Error: Invalid argument
at Error (native)
at t_vDev.(anonymous function).self.controller.devices.create.handler (automation/modules/ZWave/index.js:3041:61)
at _.extend.performCommand (automation/classes/VirtualDevice.js:291:37)
at ZAutomationAPIWebRequest._.extend.performVDevCommandFunc (automation/ZAutomationAPIProvider.js:356:60)
at ZAutomationAPIWebRequest.handlerFunc (automation/ZAutomationAPIProvider.js:3026:52)
at ZAutomationAPIWebRequest.ZAutomationWebRequest.handleRequest (automation/WebserverRequestRouter.js:259:41)
at automation/WebserverRequestRouter.js:32:35
at WebServer.document_root (automation/Webserver.js:29:11)
[2017-01-04 16:17:18.592] [core] Notification: device-info (device-status): {"dev":"WBH SRT 321 Set Point (12.0)","l":"18.5 °C"}
[2017-01-04 16:17:19.177] [core] --- ZWayVDev_zway_12-0-67-1 performCommand processing: {"0":"exact","1":{"level":"18.5"}}
[2017-01-04 16:17:19.178] [D] [zway] SETDATA devices.12.instances.0.commandClasses.67.data.1.setVal = 18.500000
[2017-01-04 16:17:19.178] [D] [zway] Job 0x13 (ThermostatSetPoint Set): removing duplicate
[2017-01-04 16:17:19.178] [D] [zway] Job 0x13 (ThermostatSetPoint Get): removing duplicate
[2017-01-04 16:17:19.178] [zway] Node 12:0 CC ThermostatMode: Thermostat Mode 1 is not supported by device (modemask 0x0)
[2017-01-04 16:17:19.180] [core] Notification: error (module): Error during perform command execution: Error: Invalid argument
[2017-01-04 16:17:19.186] [I] [core] Error: Invalid argument
at Error (native)
[2017-01-04 16:17:20.441] [I] [core] --- ZWayVDev_zway_12-0-67-1 performCommand processing: {"0":"exact","1":{"level":"18.5"}}
[2017-01-04 16:17:20.442] [D] [zway] SETDATA devices.12.instances.0.commandClasses.67.data.1.setVal = 18.500000
[2017-01-04 16:17:20.442] [D] [zway] Job 0x13 (ThermostatSetPoint Set): removing duplicate
[2017-01-04 16:17:20.442] [D] [zway] Job 0x13 (ThermostatSetPoint Get): removing duplicate
[2017-01-04 16:17:20.442] [I] [zway] Node 12:0 CC ThermostatMode: Thermostat Mode 1 is not supported by device (modemask 0x0)
[2017-01-04 16:17:20.444] [I] [core] Notification: error (module): Error during perform command execution: Error: Invalid argument
[2017-01-04 16:17:20.446] [D] [zway] Job 0x13: deleted from queue
[2017-01-04 16:17:20.450] [I] [core] Error: Invalid argument
at Error (native)
[2017-01-04 16:17:20.507] [D] [zway] Job 0x13: deleted from queue
[2017-01-04 16:17:20.517] [D] [zway] Job 0x13: deleted from queue
[2017-01-04 16:17:20.588] [D] [zway] Job 0x13: deleted from queue
The above appeared whilst using the widget. I think the reason there is more than one is because the widget emits several values while it is being adjusted.
RaZberry Z-Wave controller
Firmware version v2.2.5
UI version 1.5.0
Linux raspberrypi 4.4.34-v7+ #930 SMP Wed Nov 23 15:20:41 GMT 2016 armv7l GNU/Linux
Raspberry Pi 3
Razberry
