[Solved] Interview failed
SparkyRih
Post by SparkyRih »
When I try to include the Z-Uno to the Razberry with Z-Way, it says that the interview failed... It only has 4 plus signs (+ ++. ..........+)
Any ideas? I've tried setting different settings for the security and multi-command, enabling them both seems to result in the most plus signs (4)...
Re: Interview failed
Sure you have excluded Z-Uno before?
SparkyRih
Post by SparkyRih »
Yes, tried that several times, I can exclude and include without any problems (apart from the interview)... I have 2 Z-Uno's, both have exactly the same problem...
Both have the latest bootloader, EU frequency, same sketch (Binary Switch)... Before one had just a SimpleBlink sketch, but at that time it didn't properly interview as well...
Also tried putting the Z-Way to factory defaults...
michap
Post by michap »
SparkyRih wrote:Also tried putting the Z-Way to factory defaults...
You also have tried to make factory reset on Z-Uno?
Very strange, never have seen such effect - only sometimes for sleeping device, if interview was not ready and an additional wakeup was needed.
Michael
SparkyRih
Post by SparkyRih »
I didn't know you could reset the Z-Uno, I found how it's done, but that doesn't fix the problem...
However, I managed to get the interview further... When I play around with clicking on the "Force interview" button I see the LED on the Razberry blinking for a couple of secons, when I time the "three press" on the Z-uno I manage to get:
Device interview stage is not complete
So it does appear to get further in the stage of the interview (when I look for the details you can see that a lot more things are "done )... I guess "the Z-Uno doesn't stay awake long enough? The red LED on the Z-Uno just blinsk for one second, while the LED on the Razberry blinks for a longer period...
Edit: When I "Force review" and wake up the Z-Uno per option (Basic, BinarySwitch, AscossiationGroupInformation, ZWavePlushInfo etc.) I can get them all to be "Done", except for "MultiChannel"... I can't get that one to be "Done "...
michap
Post by michap »
The Z-Uno LED should flash for some time.
Try again with multiple very short pressing on the button - no problem if more than 3 times....
Michael
SparkyRih
Post by SparkyRih »
I'm not sure if you saw my edit:
I've done this with both Z-Uno's now, both have exactly the same result...
michap
Post by michap »
hm...
what sketch did you try? Still "simple binary sensor" sketch?
My Arduino settings: Security disabled, Multicommand disabled.
Have tried just now include via Expert and via SmartHome UI - both are working, full included ....
Using Raspberry with RaZberry modul.
Michael
SparkyRih
Post by SparkyRih »
I had them both enabled, now that I disabled them, still exactly the same issue... I did exclude/include after I pushed the sketch with both those options disabled...
http://misc.schattorie.nl/zwave/MOV00014.AVI (sorry for the bad quality, both my phones capable of 1080p video are empty and turn off when I try to shoot a video, so I used an old PSP XD this is the story of my life, if something is not working, nothing is working :D )
Please send me on support@ the Z-Way log. From Z-Way start to Z-Uno exclusion/inclusion
