Fibaro RGBW
Thor1972
Fibaro RGBW
Post by Thor1972 »
Hallo, how can i change the Parameter 14 of the Fibaro RGBW Controller, the Parameter ist not availible on my zway controller.
I con control the colors withe the dimmer switch for red, green and blue, but i can not control the colors with the color dimmer, the dimmer change the color to blue and green and no other color.
Z-Wave Support
Re: Fibaro RGBW
Post by Z-Wave Support »
Go to Expert Commands, then go to Configuration.
At this point you can get the status via Get and change the parameter with Set.
A review of the setting can be done by clicking on Configuration, you can see the setting has been adopted. Green means current. Red means it is no longer actual.
Z-Wave Support
