Hi!
Has the RaZberry support for COMMAND_CLASS_METER_TBL_CONFIG?
I'm trying to include a Kamstrup meter, http://products.z-wavealliance.org/products/255 into my network and it doesn't work 100%. Or I don't get any energy values anyhow.
In the logfile during inclusion which I have attached I found the following,
[2017-01-21 17:04:52.300] [D] [zway] Node 44:0 supports CC UNKNOWN 0x3c.
and that I can find through search on zwave sites 0x3c is defined as command class meter tbl config.
Regards
Lars
- kamstrup_logfile.zip
- Logfile
- (16.45 KiB) Downloaded 408 times
Re: COMMAND_CLASS_METER_TBL_CONFIG
I run firmware v2.2.4.
No. We only support MeterTableMonitor. Never had time to try the MeterTableConfig.
Do you have any plans to add this? I can send you a meter for free if you want to add this. Just send me the address to my email.
Well, never though about it as have never seen any device supporting it.
Had a look into spec, looks it is damn simple - only allows to set Meter Point Administration Number. No idea whit is this Number, but looks it is pretty easy to implement.
Any idea what is it made for? What will happen to your Kamstrup when you will issue that command?
Of course having the device in hands will simplify the implementation (about 1-2 hours to implement), but may be remotelly is also possible.
Hi!
See the attach xml that a Kamstrup meter has for deviceinfo. The file was created on another type of Zwave-system
If I connect the Kamstrup meter to my RaZberry-system I only get 2 item, General purpose and a Switch. I don't know if adding CC MeterTblConfig would solve everything.
//LLars
//LLars
- kamstrup_device.zip
- (857 Bytes) Downloaded 384 times
Looks like it just fail to pass interview. Can you include it again? I don't think MeterTableConfig is something that you need. It should work even w/o it
Been away for some time but now I'm back...
I have now updated to v2.3.0 and exclude/included the meter again.
The only difference is that I get a double set of "General purpose and a Switch". But no power or meter standing...
Can you send us the log of inclusion?
Here is the log file. Lock for device.46 //Lars
- inclusion_kamstrup.log.zip
- (41.54 KiB) Downloaded 363 times
