eedomus and multiple binary channels
SergioP
Post by SergioP »
I have an eedomus z-wave controler and I have been playing with the z-uno in a multichannel sketch where I have set up 4 bynary channels connected to pins 9 to 12 and 2 multilevel connected to pins 14 and 15. All have a led connected so I can identify when they are getting fired and when not. I have compiled, upload to z-uno and make exclusion and inclusion in eedomus.
What I see is that both multilevel work fine. bynary are all asociated with th same led (I cannot identify which one as eedomus has renumbered channels to 1 up to 4).
I have made unit testing but removing all code and leaving only 1 switch (have tried this with all 4) and is working fine.
Is there anything missing in my sketch? I am attaching the code and also what I see in eedomus.
Thanks for your help.
Regards,
Sergio
Sergio
Investigating for fun. Trying more confortable DIY home appliances
SergioP
Re: eedomus and multiple binary channels
Post by SergioP »
Sorry I cannot upload attachments.... so I put my sketch here:
// LED pin number
#define LED_PIN9 9 // swith on/off
#define LED_PIN10 10 // swith verano/invierno
#define LED_PIN11 11 // dimmer TempCal (seleccion Temperatura caldera)
#define LED_PIN12 12 // dimmer ACS (seleccion temperatura Agua caliente)
// Global variables to store data reported via getters
byte switchValue9 = 0;
byte switchValue10 = 0;
byte switchValue11 = 0;
byte switchValue12 = 0;
byte switchValue14 = 0;
byte switchValue15 = 0;
// Set up 6 channels
ZUNO_SETUP_CHANNELS(
ZUNO_SWITCH_BINARY(getterSwitch9, setterSwitch9),
ZUNO_SWITCH_BINARY(getterSwitch10, setterSwitch10),
ZUNO_SWITCH_BINARY(getterSwitch11, setterSwitch11),
ZUNO_SWITCH_BINARY(getterSwitch12, setterSwitch12),
ZUNO_SWITCH_MULTILEVEL(getterSwitch14, setterSwitch14),
ZUNO_SWITCH_MULTILEVEL(getterSwitch15, setterSwitch15)
// ZUNO_SETUP_DEBUG_MODE(DEBUG_ON);
// ZUNO_SETUP_DEBUG_MODE(DEBUG_OFF);
void setup() {
// set up I/O pins. Analog and PWM will be automatically set up on analogRead/analogWrite functions call
pinMode(LED_PIN9, OUTPUT);
pinMode(LED_PIN10, OUTPUT);
pinMode(LED_PIN11, OUTPUT);
pinMode(LED_PIN12, OUTPUT);
//pinMode(LED_PIN14, OUTPUT);
//pinMode(LED_PIN15, OUTPUT);
void loop() {
// Empty
// Getters and setters
void setterSwitch9(byte value) {
digitalWrite(LED_PIN9, (value > 0) ? HIGH : LOW);
switchValue9 = value;
byte getterSwitch9(){
return switchValue9;
void setterSwitch10(byte value10) {
digitalWrite(LED_PIN10, (value10 > 0) ? HIGH : LOW);
switchValue10 = value10;
byte getterSwitch10(){
return switchValue10;
void setterSwitch11(byte value11) {
digitalWrite(LED_PIN11, (value11 > 0) ? HIGH : LOW);
switchValue11 = value11;
byte getterSwitch11(){
return switchValue11;
void setterSwitch12(byte value12) {
digitalWrite(LED_PIN12, (value12 > 0) ? HIGH : LOW);
switchValue12 = value12;
byte getterSwitch12(){
return switchValue12;
void setterSwitch14(byte value14) {
byte tempVariable14;
// value is a variable, holding a "new value"
// which came from the controller or other Z-Wave device
if (value14 > 99) {
// by Z-Wave specification, this value can't be more then 99
value14 = 99;
// but the LED brightness scale ranges from 0 to 255
// we need to prepare our "value" for this new scale
tempVariable14 = (((word)value14) * 255 / 99);
// now we set the LED brightness
analogWrite(PWM2, ((long)value14) * 255 / 99);
// we'll save our value for the situation, when the controller will ask us about it
switchValue14 = value14;
byte getterSwitch14(){
return switchValue14;
void setterSwitch15(byte value15) {
byte tempVariable15;
if (value15 > 99) {
value15 = 99;
tempVariable15 = (((word)value15) * 255 / 99);
analogWrite(PWM3, ((long)value15) * 255 / 99);
switchValue15 = value15;
byte getterSwitch15(){
return switchValue15;
Sergio
SergioP
Post by SergioP »
I have made another test by miodifying mi sketch to have 4 multilever switch and 2 binary switch and the multilevers work fine while binaries still both acting on the same pin (asume same channel).
So the problem is with the binary switches.
Regards,
Sergio
Sergio
Are you sure your controller is sending commands on individual channels? May be controller sends always to the same channel?
SergioP
Post by SergioP »
Hi PoltoS,
Thanks for your reply. Do you hace any idea on how to check ?
Sergio
Check logs of eedomus.
eedomus-team
Post by eedomus-team »
Hi SergioP,
You are right. We have found an issue with the integration of Z-Uno with multiple binary channels with eedomus gateway.
It is now corrected (available in next version, contact our support for immediate update).
Thanks Z-Wave-Me for this innovative Z-Uno product.
Best regards
Clark - eedomus team
Clark, thanks for adding support of Z-Uno in eedomus.
If you can give me a summary what is supported and what is not (channel types, multiple channels of same type, polymorphism) and a screenshot of a 10 channel sketch and we will publish it on our page about controllers support: https://z-uno.z-wave.me/z-wave/interope ... ntrollers/
SergioP
Post by SergioP »
Poltos, Clark,
Thanks with your help on this Issue. I can help testing many of the required features of z-uno and I have gota año eedomus. Just let me know. I have límited bandwith but am quite interested ni making this workable. Also , we may engage other people using eedomus ( and eedomus plus ) to help with the testing.
Regards,
Sergio
Sergio
