I have a HeatIT Thermostat that stops interviewing at 92% - missing the CommandClass "Meter". As a result of this it seems like when it tries to "re-interview" later on the device gets corrupt (don't have access to the already CommandClass that was successfully added.
I'm new to this - so whould be very pleased with any help.
//Jan-Erik
Issue interviewing HeatIT thermostat
Re: Issue interviewing HeatIT thermostat
The log can help us to understand why Meter don't pass
anesthesia
having the same problem with the non complete interview. I attached a log file. My Heat IT is "devices.2.".
Thanks in advance
Thanks in advance
- heatit_interview_partial.zip
- Heat It Interview
- (42.63 KiB) Downloaded 1214 times
anesthesia
Is there any solution how to fix the incomplete interview with the thermostat?
Thanks in Advance
Thanks in Advance
Not that it´s any help. But Heatit/multireg does not have an working metering function. So if its missing it doesn´t matter since it doesnt produce any data.
You have to wait until v2 device comes out later this year for metering
@anesthesia, should we look into that log after the comment by @jeey?
anesthesia
It would be nice if you could take a look. If the meter does not work properly, is there a way to deactivate it? It would be usefull to get the interview complete.
Did anyone find a solution to this. I recently installed the same unit and have the same problem, interview sticks at 92% and it seems it tries to re-interview the device which drops it out of the ui as it always fails. Is there any way to remove the 'meter' function from the device so that the interview completes successfully?
Any updates on this? Having the same issue. Irritating as...
There is a way the remove this meter feature via fixing internal Z-Way structures. But better to as for new fw from HeatIt with this bug fixed
