Hi!
My RaZbeery Pi is driving me mad, I have system crashes repeating every few days. I did a clean install of the whole system 4 times because I was even not able to recover from backup images.
What happens:
The system runs nice for a given time and then starts to do unnormal things.. While I am doing some configuration stuff for example, it gets stuck and does not answer any more.
The reboot then throws many error messages. I attached the log, most time the issue has to do with the udev Kernel Device Manager
I exchanged nearly everything in regards of hardware:
The power supply unit, the power cable, the SD card and also the complete Raspi 3. (Not yet the daughter board itself)
Hope anyone could help....
RazBerry board causes system crashes
- 3a6c365daa1507b028406bc21c5f48911572dfb0.jpg (947.23 KiB) Viewed 6482 times
Re: RazBerry board causes system crashes
This is far beyond Z-Way coverage. Why do you think that RaZberry board is causing this? Sure you have installed it correctly on the Pi?
