atoi
10der
atoi
Post by 10der »
hello!
how to convert char* to int
standard c++ atoi function is not supported by z-uno core.
thanks!
10der
Re: atoi
Post by 10der »
(facepalm)
int toInt(char* str) {
  int s = 1;
  int i = -1;
  int res = 0;
  if (str[0] == '-') {
    s = -1;
    i = 0;
  while (str[++i] != '\0') { //iterate until the array end
    res = res * 10 + (str[i] - '0'); //generating the integer according to read parsed numbers.
  res = res * s;
#ifdef DEBUG
  Serial.println(res);
#endif
  return res;
Re: atoi
We will add atoi in 2.0.9. It should already be in strings.h, but probably the prototype is not declared in headers. We will take care
Re: atoi
milimilo
Re: atoi
Post by milimilo »
It seems that atoi/atol/atof are still not supported even in 2.1
I still have an error message.
Re: atoi
It was tested to work. Lease send us more info to reproduce it
