I did a fresh install of Z-Way 2.3.1 and connected a Fibaro Wall Plug.
But i cannot change parameters on the configuration tab in the Expert UI.
What's wrong?
Configuration is not supported
- zway.png (14.54 KiB) Viewed 11032 times
- Z-Wave Support
Re: Configuration is not supported
this is a very nice bug
. You can still configure your parameters.
I have send this to development.
regards
Z-Wave Support
regards
Z-Wave Support
Oh a bug
And how can I configure the parameters?
Or do I have to wait till the bug is resolved?
anders.bostrom
I have a similar problem. I have 5 Fibaro FGWPE/F-102 ZW5 that all can be included properly, but it's impossible to change configuration. Sometimes There seems to be some config that is transmitted as the wall plug changes something (like color on LED when plug is off changes to white from the default "off", and there is no way to get it back other than wall plug factory reset). Have tried everything including factory reset of Razberry, un/re-install of z-way.
Nothing works.
Is there a way to manually adjust config via javascript api or via command line in raspbian?
/Anders
Nothing works.
/Anders
- Z-Wave Support
you can change the device description to FGWP E/F 101. Then you have the Parameters. Or you read the manual ans set the Parameter manually.
http://manuals-backend.z-wave.info/make ... GWPE-102-5
regards
Z-Wave Support
regards
Z-Wave Support
HoferSackal
I had the same problem and tried to change the device description (i tried every device) and one of them worked. Now i can adjust every parameter.
Regards,
Michael
Regards,
Michael
