Fibaro Door/Window Sensor - Reset tamper
vegardb123
Post by vegardb123 »
Hi!
I've got a Window/Door Sensor from Fibaro, and the tamper alarm is constantly in an "ON" state. The alarm is activatet by pushing the button on the back of the sensor.
This isn't a problem when using for example a Fibaro Motion Sensor, because that sensor resets the tamper alarm after a set time.
How can I reset the tamper alarm in the Door/Window sensor without having to remove it from the system and adding it again every time? Is there any script commands I can use?
Thanks!
- Vegard
