MultiChannel association problem
e-rook
Post by e-rook »
Hello
I am using most recent Z-wave.me software and I have problem with MultiChannel - either I do not understand or I have issue:
I have:
* two channel wall switch TKB Home TZ37 with Command Classes interviewed - Basic • SwitchBinary • SwitchAll • SceneActivation • SceneActuatorConf • AssociationGroupInformation • DeviceResetLocally • ZWavePlusInfo • MultiChannel • Configuration • ManufacturerSpecific • PowerLevel • FirmwareUpdate • Association • Version • SwitchBinary • SwitchBinary •
* Philio switch 2x1.5kW PAN04 with CC - Basic • SwitchBinary • SwitchAll • SceneActivation • SceneActuatorConf • Meter • AssociationGroupInformation • DeviceResetLocally • ZWavePlusInfo • MultiChannel • Configuration • Alarm • ManufacturerSpecific • PowerLevel • Protection • FirmwareUpdate • Association • Version • Basic • SwitchBinary • Meter • Basic • SwitchBinary • Meter • Basic • SwitchBinary • Meter •
I would like to create association which:
* left double-click on TZ37 turns on/off PAN04 channel 1
* right double-click on TZ37 turns on/off PAN04 channel 2
So far I can only associate that double click turns PAN04 globally - meaning both channels.
When checking Expert Commands I have empty MultiChannel section and in Association I cannot choose separate channels. Can you advice me if my thinking is correct and I should be able to have such kind of switching - and if so - how to achieve it?
Cheers,
Piotr "Rook"
Expert Commands section
e-rook
Re: MultiChannel association problem
Post by e-rook »
Can anybody confirm if at least my MultiChannel understanding is correct?
You are looking for MultiChannelAssociations.
MultiChannel should be supported in target device
