Web camera
Web camera
Does anyone now how to enter a valid url adress when you enter a web camera in devices?
Re: Web camera
To stream in vlc i use "rtsp://192.168.0.10:554/user=admin&password=&channel=1&stream=0.sdp?real_stream" but this i cant use in the setup for the web camera.
Any help is appreciated, thanks in advance.
- webcamera.jpg (76.54 KiB) Viewed 7889 times
- Z-Wave Support
Re: Web camera
you cannot use the live stream with this app.
You find the string for your camera here: https://www.ispyconnect.com/sources.aspx
Add the string with username and password in the line and the fields username and password muss be empty
Best regards
Z-Wave Support
Best regards
Z-Wave Support
Re: Web camera
I have tried all off them under the brand I use, it still says that it is not a valid URL. Does anyone have an example on how a valid string looks like.
