How to reuse a device number
platypus
Re: How to reuse a device number
Post by platypus »
It's 2019 and I'm using the latest version 2.3.8. A sensor gave strange values, I opened it's housing to check it and reset it locally by mistake. It was still present in the list of devices and I tried to reassign the device but I couldn't find a way to do that. It's frustrating to do all the configuration again. When I add the device as new, the next free number would be 2 but it takes 19.
You should use Replace Failed Node button in the Expert UI
If you already excluded the device from the network (on the controller side), you can not use this feature anymore
