Razberry PoweLevel
PaWel
Razberry PoweLevel
Post by PaWel »
Is it possible to change the z-wave wireless power level?
In expert view I have the option of Power Level but I get the Error: Method not implemented devices[1].instances[0].commandClasses[115].Set(5,0). Maybe there is other way to change this value?
Power Level Change Error
Moreover there is -9dBm by default. Is it the strongest signal or the weakest?
Re: Razberry PoweLevel
You have to select the node Id. But this will not last long - after powercycle the node will have same power level again.
Why do you want to decrease it? By default this level is the maximum one
