Order of executions when starting Z-Way server.
vegardb123
Post by vegardb123 »
Hi!
I've made a virtual device (switch), and in a custom script I try to get and use its level (on/off). The problem is that when I restart the z-way server, it executes the custom scripts before the DummyDevice module is initialized. This leads to errors where the script uses "on" or "get", since the device doesn't "exist" yet (or at least I think that's why?).
Is there any way to change the order of executions when starting the Z-Way server so that the DummyDevice is initialized before the custom script is executed?
Re: Order of executions when starting Z-Way server.
You can make a hook in custom code to trap DummyDevice changes. check of devices.get("myDummy").on(function() {...})
