UART Settings : Parity and Stop bits.
slash4u
Post by slash4u »
Hi all, I've just started working with the Z-Uno and did not find a way to set UART settings ( Parity and Stop bits ). I need to set 7-E-1 instead of default 8-N-1. Do you know how I can do this ?
Re: UART Settings : Parity and Stop bits.
8-N-1 is the only possible option. Unfortunatelly, this is hardware limitation of ZM5101 chip. You need to use some converter for your project.
