Before i was running rapbian and my razberry card was running fine. Now i reinstalled my rpi with minibian, mainly because aspbian was running very slow. But bow i am not able to get my razberry gpio card running.
when i manually start it i get this:
./z-way-server
./z-way-server: error while loading shared libraries: libzcommons.so: cannot open shared object file: No such file or directory
root@minibian-domoticz:/opt/z-way-server#
i already symlinked this
ln -s /usr/lib/arm-linux-gnueabihf/libarchive.so.13 /usr/lib/arm-linux-gnueabihf/libarch ive.so.12 as read somewhere else
in the gui i see this
An unexpected error occurred while initialising the Z-Wave controller data.
Please check
1.) if the controller is plugged in correctly,
2.) that in the app 'Z-Wave Network Access' the right port is entered
(UZB: '/dev/ttyACM0', Box: '/dev/ttyAMA0', UZB-Windows: '\\\\.\\COM3', Z-Stick: '/dev/ttyUSB0', embedded boxes: '/dev/ttyS0' or '/dev/ttyS1')
3.) the app is aktiv. If not you could activate it under Menu > Apps > Activ or add a new one under Menu > Apps > Local.
The Setting 'Expert View' needs to be active under Menu > My Settings.i am running the lastest zway server z-way-server-RaspberryPiXTools-v2.3.4.tgz
