Reset Rzberry or reclaim old IDs?
SubnetMask
Is there a way to clear out the config on the Razberry so that the entire network config is gone and one could start from scratch at ID 1, or is there a way to removed old IDs that had been used but are long gone so that they can be put to use again? I have a lot of IDs that are from old nodes that hhave been removed for one reason or another - some cases they flaked out so I had to remove and re-add them, and they got a new ID, others they failed or I just removed the old node.But whenever a node is removed, while its ID is no longer in use, I have never been able to 'recycle' the IDs. Am I missing something?
Re: Reset Rzberry or reclaim old IDs?
I got same question - anybody here, who has an answer?
Last time when i struggled around with including, reencluding a broken device, the system was using older ID´s.
Before it always counts up, so i assume that it´s working.
