Global Cache broken?
mattiaslundin
Post by mattiaslundin »
I cant seem to get the Global Cache app to work with commands to my itach. I use exactly the same command that work fine in iLearn but nothing gets triggered when i use the app. Is the app broken or should i spend more time tracing what is actually happening?
Re: Global Cache broken?
Should work. Actually the app is simply sending an http request, so you can first check if the same request works from the browser.
vpustisek
Post by vpustisek »
Hi, doesn't work for me as well. Any luck with getting it work?
My iTach is correctly configured and I have managed to use netcat to send IR commands but no luck using it through Global Cache module on Z-Way...
vpustisek
Post by vpustisek »
Hi, any answers to the above questions?
