Analytics menu not showing in z-way expert mode
Tom_Tron
Post by Tom_Tron »
Hi I have a question, I’m using the "USB Z-wave Transceiver” model ZMEXUZB1 . the USB stick is working fine but I wish to access the Analytics menu in order to use the noise detection functionality but it’s not currently showing .how do I get the Analytics menu to show
Re: Analytics menu not showing in z-way expert mode
You need to upgrade do the fw 5.27
Tom_Tron
No Background noise showing in zway Analytics menu
Post by Tom_Tron »
Hi, I’ve managed to get the Analytics menu to show by using a Raspberry PI GPIO connector instead of the usb Z-wave Transceiver as first mentioned in previous post. The problem is background noise screen is showing no background noise. I left the background noise screen on for 30 minutes and there was no change to the noise level. This result is unexpected as the area that I’ve placed the zway raspberry pi should have lots of z-wave and electrical activity so I would expect to see some kind of noise. Also The noise meter show zero all the time. Do you have any ideas as to why zway is picking up no background noise ?
Tom_Tron
Post by Tom_Tron »
here is hat happens in the logs the main error seems to be "(Get background noise level): RSSI Ch#1: too low, Ch#2: too low, Ch#3: invalid"
2017-10-10 13:44:39.992] [core] Starting automation...
[2017-10-10 13:44:40.006] [core] Starting storage...
[2017-10-10 13:44:40.007] [core] ZWay Automation started
[2017-10-10 13:45:06.168] [D] [zway] Job 0x07: deleted from queue
[2017-10-10 13:45:06.189] [D] [zway] Job 0xf5: deleted from queue
[2017-10-10 13:45:06.189] [D] [zway] Job 0x06: deleted from queue
[2017-10-10 13:45:06.189] [D] [zway] Job 0x17: deleted from queue
[2017-10-10 13:45:06.189] [D] [zway] Job 0xd2: deleted from queue
[2017-10-10 13:45:06.199] [D] [zway] Job 0xf2: deleted from queue
[2017-10-10 13:45:06.199] [D] [zway] Job 0x20: deleted from queue
[2017-10-10 13:45:06.210] [D] [zway] Job 0x05: deleted from queue
[2017-10-10 13:45:06.210] [D] [zway] Job 0x15: deleted from queue
[2017-10-10 13:45:06.210] [D] [zway] Job 0x56: deleted from queue
[2017-10-10 13:45:06.260] [D] [zway] Job 0x02: deleted from queue
[2017-10-10 13:45:06.482] [D] [zway] Job 0x2a: deleted from queue
[2017-10-10 13:45:06.483] [D] [zway] Job 0x41: deleted from queue
[2017-10-10 13:45:06.493] [D] [zway] Job 0x80: deleted from queue
[2017-10-10 13:45:06.493] [D] [zway] Job 0x03: deleted from queue
[2017-10-10 13:45:06.503] [D] [zway] Job 0x05: deleted from queue
[2017-10-10 13:45:06.523] [D] [zway] Job 0x3a: deleted from queue
[2017-10-10 13:45:16.352] [zway] Adding job: Get background noise level
[2017-10-10 13:45:16.361] [D] [zway] SENDING: ( 01 03 00 3B C7 )
[2017-10-10 13:45:16.362] [D] [zway] RECEIVED ACK
[2017-10-10 13:45:16.371] [D] [zway] RECEIVED: ( 01 05 01 3B 7D 7D C0 )
[2017-10-10 13:45:16.371] [D] [zway] SENT ACK
[2017-10-10 13:45:16.371] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel1 = 125 (0x0000007d)
[2017-10-10 13:45:16.371] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel2 = 125 (0x0000007d)
[2017-10-10 13:45:16.371] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel3 = 127 (0x0000007f)
[2017-10-10 13:45:16.372] [zway] Job 0x3b (Get background noise level): RSSI Ch#1: too low, Ch#2: too low, Ch#3: invalid
[2017-10-10 13:45:16.372] [D] [zway] Job 0x3b (Get background noise level): success
[2017-10-10 13:45:16.372] [zway] Removing job: Get background noise level
[2017-10-10 13:45:36.519] [D] [zway] Job 0x3b: deleted from queue
[2017-10-10 13:45:46.359] [zway] Adding job: Get background noise level
[2017-10-10 13:45:46.363] [D] [zway] SENDING: ( 01 03 00 3B C7 )
[2017-10-10 13:45:46.364] [D] [zway] RECEIVED ACK
[2017-10-10 13:45:46.373] [D] [zway] RECEIVED: ( 01 05 01 3B 7D 7D C0 )
[2017-10-10 13:45:46.373] [D] [zway] SENT ACK
[2017-10-10 13:45:46.373] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel1 = 125 (0x0000007d)
[2017-10-10 13:45:46.373] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel2 = 125 (0x0000007d)
[2017-10-10 13:45:46.373] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel3 = 127 (0x0000007f)
[2017-10-10 13:45:46.373] [zway] Job 0x3b (Get background noise level): RSSI Ch#1: too low, Ch#2: too low, Ch#3: invalid
[2017-10-10 13:45:46.373] [D] [zway] Job 0x3b (Get background noise level): success
[2017-10-10 13:45:46.373] [zway] Removing job: Get background noise level
Tom_Tron
Post by Tom_Tron »
alo I'm running z-way-server v2.3.6 on Debian
I upgraded the the firmware to the lastest on the Razberry Z-Wave chip
