Opnehab 2 interoperability proposal
aleconakad
Post by aleconakad »
I am currently working on supporting a sketch under Openhab2. It works fine when I define the device XML in OH2 correctly.The problem arises if I want to have a second Z-Uno with another sketch supported, because OH2 does not support yet dynamic endpoint detection and still requires a predefined device XML for accurate device detection.
After checking the reported node xml from OH2 corresponding to the Z-Uno device, I see that the Command Class Version is reported back as supported (I guess this is a must for each Z-Wave device). The application version being reported is in my case 2.11, that is the latest Z-Uno firmware version.
Is it possible to provide an API for Z-Uno to be able to set this application version from inside a sketch?
By doing so, we can set a different version for each sketch, and based on this version, we define a specific device xml in the openhab2 binding fitting to the endpoints of this sketch. This will provide a 100% interoperability for multiple Z-Uno devices in the same network under Openhab2.
Do you think it is possible to include such change in next update?
Re: Opnehab 2 interoperability proposal
Hi!
We think abiutaking ProductID configurable. In 2.1.3
aleconakad
Thanks! :D
When is it due?
aleconakad
Hi!
can I already start trying out the configurable ProductID feature in some beta release?
When is 2.1.5 due?
We will make a pre-beta next week or so. This feature is already implemented, please wait a bit more
aleconakad
@PoltoS:
any update on this?
Too many changes, so it took more time. This month we plan to make a beta
noryn
Post by noryn »
Any progress on this? I can`t see in 2.1.5 changelog...
Edit found it...
Possibility to change Product Type Id and Prodyuct Id
Before 2.1.5 all Z-Uno sketches were detected ProductType/ProductId 0x0110/0x0001. This lead to problems in some controllers that had a template for specific devices - two different Z-Uno were detected using the same UI template.
2.1.5 is out. You can see in the forum. But no announcement yet since we have not made changes in the documentation.
See details in https://forum.z-wave.me/viewtopic.php?f=3427&t=32570
I suggest to use the mode where Z-Uno sets the I'd based on channel types. This is the easiest and most universal
