Zway remote access cant log in
Bossman
Post by Bossman »
Did a new install on PI3 and then installed z-wave.me. went to find.z-wave.me and login screen opened but keeps saying remote access not possable or wrong password.
Please help me get to location to verify user name and password. I tried the Remote Id and password that was in terminal during install but not working.
When I click on the Ip below Login box it opens up browser that says The site cant be reached.
I am lost. Very new to Razberry and All I want to do with it is get the Zwave.me working for now.
Bossman
Re: Zway remote access cant log in
Post by Bossman »
I tried doing as it says.
I am using the Remote ID and password that populates during install. Still no luck logging in.
Does anybody have the know how to lead me to the user name and password for Zway on my PI?
enbemokel
Post by enbemokel »
As this is a new installation, are you using stretch or jessie.
I read about problems with stretch and not working with z-way, but don´t know exactly whats the problem.
Maybe you should try jessie.
IgoriokLT
Post by IgoriokLT »
Did you try to login locally? Login is "admin"
Bossman
Post by Bossman »
enbemokel wrote:
30 Nov 2017 13:51
I downloaded NOOBS V2_4_4 and from it I loaded the Raspbian OS. I have not found where it says what version of Raspbian it has with it
enbemokel
Post by enbemokel »
Hi, seems to be stretch, as there is a hint on the download side:
https://www.raspberrypi.org/downloads/noobs/
that it contains Raspbian. If you click on this link it shows the stretch image......
Bossman
Post by Bossman »
enbemokel wrote:
01 Dec 2017 16:31
This was installed with the NOOBS
Here is what I did in the command line and got:
pi@raspberrypi:~ $ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
NAME="Raspbian GNU/Linux"
VERSION_ID="9"
VERSION="9 (stretch)"
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
So I see that it is not the jessie version but i have searched the internet and cant seem to find the right version.
Bossman
Post by Bossman »
Ok I think I found the jessie version.here http://downloads.raspberrypi.org/raspbi ... 017-07-05/
Is it possable to load it from the PI that I installed noobs on? Or when I install without noobs how do I get to a desktop for downloading the zway to pi?
Bossman
Post by Bossman »
Alright after I found the jessie version I installed it and it came up in the desktop showing. from there I went to command and did as follows
pi@raspberrypi:~ $ wget -q -O - razberry.z-wave.me/install | sudo bash
Do you accept Z-Wave.Me licence agreement?
Please read it on Z-Wave.Me web site: http://razberry.z-wave.me/docs/ZWAYEULA.pdf
yes/no: yes
z-way-server new installation
Installing additional libraries
Get:1 http://mirrordirector.raspbian.org jessie InRelease [14.9 kB]
Get:2 http://archive.raspberrypi.org jessie InRelease [22.9 kB]
Get:3 http://mirrordirector.raspbian.org jessie/main armhf Packages [9,536 kB]
Get:4 http://archive.raspberrypi.org jessie/main armhf Packages [171 kB]
Get:5 http://archive.raspberrypi.org jessie/ui armhf Packages [58.9 kB]
Ign http://archive.raspberrypi.org jessie/main Translation-en_GB
Ign http://archive.raspberrypi.org jessie/ui Translation-en_GB
Get:6 http://mirrordirector.raspbian.org jessie/contrib armhf Packages [43.3 kB]
Get:7 http://mirrordirector.raspbian.org jessie/non-free armhf Packages [84.2 kB]
Get:8 http://mirrordirector.raspbian.org jessie/rpi armhf Packages [1,356 B]
Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/main Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en_GB
Fetched 9,933 kB in 25s (389 kB/s)
Reading package lists... Done
Building dependency tree
Reading state information... Done
tzdata is already the newest version.
Suggested packages:
gawk-doc bsd-mailx mailx
The following NEW packages will be installed:
gawk libsigsegv2 sharutils
The following packages will be upgraded:
libc-ares2
1 upgraded, 3 newly installed, 0 to remove and 68 not upgraded.
Need to get 803 kB of archives.
After this operation, 2,934 kB of additional disk space will be used.
Get:1 http://mirrordirector.raspbian.org/raspbian/ jessie/main libsigsegv2 armhf 2.10-4 [28.2 kB]
Get:2 http://mirrordirector.raspbian.org/raspbian/ jessie/main gawk armhf 1:4.1.1+dfsg-1 [480 kB]
Get:3 http://mirrordirector.raspbian.org/raspbian/ jessie/main libc-ares2 armhf 1.10.0-2+deb8u2 [66.7 kB]
Get:4 http://mirrordirector.raspbian.org/raspbian/ jessie/main sharutils armhf 1:4.14-2 [228 kB]
Fetched 803 kB in 2s (274 kB/s)
Reading changelogs... Done
Selecting previously unselected package libsigsegv2:armhf.
(Reading database ... 115401 files and directories currently installed.)
Preparing to unpack .../libsigsegv2_2.10-4_armhf.deb ...
Unpacking libsigsegv2:armhf (2.10-4) ...
Setting up libsigsegv2:armhf (2.10-4) ...
Processing triggers for libc-bin (2.19-18+deb8u10) ...
Selecting previously unselected package gawk.
(Reading database ... 115411 files and directories currently installed.)
Preparing to unpack .../gawk_1%3a4.1.1+dfsg-1_armhf.deb ...
Unpacking gawk (1:4.1.1+dfsg-1) ...
Preparing to unpack .../libc-ares2_1.10.0-2+deb8u2_armhf.deb ...
Unpacking libc-ares2:armhf (1.10.0-2+deb8u2) over (1.10.0-2+deb8u1) ...
Selecting previously unselected package sharutils.
Preparing to unpack .../sharutils_1%3a4.14-2_armhf.deb ...
Unpacking sharutils (1:4.14-2) ...
Processing triggers for man-db (2.7.5-1~bpo8+1) ...
Processing triggers for install-info (5.2.0.dfsg.1-6) ...
Setting up gawk (1:4.1.1+dfsg-1) ...
Setting up libc-ares2:armhf (1.10.0-2+deb8u2) ...
Setting up sharutils (1:4.14-2) ...
Installing additional libraries for HomeKit
The following extra packages will be installed:
libavahi-client-dev libavahi-common-dev libavahi-compat-libdnssd1 libdbus-1-dev
libavahi-client-dev libavahi-common-dev libavahi-compat-libdnssd-dev libavahi-compat-libdnssd1 libdbus-1-dev
0 upgraded, 5 newly installed, 0 to remove and 68 not upgraded.
Need to get 402 kB of archives.
After this operation, 1,160 kB of additional disk space will be used.
Get:1 http://mirrordirector.raspbian.org/raspbian/ jessie/main libavahi-compat-libdnssd1 armhf 0.6.31-5 [42.9 kB]
Get:2 http://mirrordirector.raspbian.org/raspbian/ jessie/main libavahi-common-dev armhf 0.6.31-5 [61.4 kB]
Get:3 http://mirrordirector.raspbian.org/raspbian/ jessie/main libdbus-1-dev armhf 1.8.22-0+deb8u1 [184 kB]
Get:4 http://mirrordirector.raspbian.org/raspbian/ jessie/main libavahi-client-dev armhf 0.6.31-5 [55.4 kB]
Get:5 http://mirrordirector.raspbian.org/raspbian/ jessie/main libavahi-compat-libdnssd-dev armhf 0.6.31-5 [57.7 kB]
Fetched 402 kB in 1s (236 kB/s)
Selecting previously unselected package libavahi-compat-libdnssd1:armhf.
(Reading database ... 115614 files and directories currently installed.)
Preparing to unpack .../libavahi-compat-libdnssd1_0.6.31-5_armhf.deb ...
Unpacking libavahi-compat-libdnssd1:armhf (0.6.31-5) ...
Selecting previously unselected package libavahi-common-dev.
Preparing to unpack .../libavahi-common-dev_0.6.31-5_armhf.deb ...
Unpacking libavahi-common-dev (0.6.31-5) ...
Selecting previously unselected package libdbus-1-dev:armhf.
Preparing to unpack .../libdbus-1-dev_1.8.22-0+deb8u1_armhf.deb ...
Unpacking libdbus-1-dev:armhf (1.8.22-0+deb8u1) ...
Selecting previously unselected package libavahi-client-dev.
Preparing to unpack .../libavahi-client-dev_0.6.31-5_armhf.deb ...
Unpacking libavahi-client-dev (0.6.31-5) ...
Selecting previously unselected package libavahi-compat-libdnssd-dev.
Preparing to unpack .../libavahi-compat-libdnssd-dev_0.6.31-5_armhf.deb ...
Unpacking libavahi-compat-libdnssd-dev (0.6.31-5) ...
Setting up libavahi-compat-libdnssd1:armhf (0.6.31-5) ...
Setting up libavahi-common-dev (0.6.31-5) ...
Setting up libdbus-1-dev:armhf (1.8.22-0+deb8u1) ...
Setting up libavahi-client-dev (0.6.31-5) ...
Setting up libavahi-compat-libdnssd-dev (0.6.31-5) ...
Making symlinks to libssl.so
Making symlinks to libcrypto.so
Installing libarchive-dev
Building dependency tree...
libarchive-dev
0 upgraded, 1 newly installed, 0 to remove and 68 not upgraded.
Need to get 393 kB of archives.
After this operation, 1,082 kB of additional disk space will be used.
Get:1 http://mirrordirector.raspbian.org/raspbian/ jessie/main libarchive-dev armhf 3.1.2-11+deb8u3 [393 kB]
Fetched 393 kB in 1s (320 kB/s)
Selecting previously unselected package libarchive-dev:armhf.
(Reading database ... 115703 files and directories currently installed.)
Preparing to unpack .../libarchive-dev_3.1.2-11+deb8u3_armhf.deb ...
Unpacking libarchive-dev:armhf (3.1.2-11+deb8u3) ...
Setting up libarchive-dev:armhf (3.1.2-11+deb8u3) ...
Making link to libarchive.so.12
Getting Z-Way for Raspberry Pi and installing
--2017-12-01 17:39:25-- http://razberry.z-wave.me/z-way-server/ ... v2.3.6.tgz
Resolving razberry.z-wave.me (razberry.z-wave.me)... 46.20.244.36
Connecting to razberry.z-wave.me (razberry.z-wave.me)|46.20.244.36|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 19893339 (19M) [application/x-gzip]
Saving to: ‘/tmp/z-way-server-RaspberryPiXTools-v2.3.6.tgz’
/tmp/z-way-server-RaspberryPiXTools-v2.3.6.tgz 100%[==================================================================================================================================>] 18.97M 351KB/s in 52s
2017-12-01 17:40:17 (377 KB/s) - ‘/tmp/z-way-server-RaspberryPiXTools-v2.3.6.tgz’ saved [19893339/19893339]
Extracting new z-way-server
New version z-way-server installed
Creating Z-Way startup script
Adding z-way-server to autostart
Getting Webif for Raspberry Pi and installing
--2017-12-01 17:40:22-- http://razberry.z-wave.me/webif_raspberry.tar.gz
Length: 412185 (403K) [application/x-gzip]
Saving to: ‘STDOUT’
- 100%[==================================================================================================================================>] 402.52K 217KB/s in 1.9s
2017-12-01 17:40:24 (217 KB/s) - written to stdout [412185/412185]
First install, getting Remote ID
--2017-12-01 17:40:25-- http://find.zwave.me/zbw_new_user
Resolving find.zwave.me (find.zwave.me)... 46.20.244.72
Connecting to find.zwave.me (find.zwave.me)|46.20.244.72|:80... connected.
Length: unspecified [application/octet-stream]
Saving to: ‘/tmp/zbw_connect_setup.run’
/tmp/zbw_connect_setup.run [ <=> ] 6.10K --.-KB/s in 0.04s
2017-12-01 17:40:26 (160 KB/s) - ‘/tmp/zbw_connect_setup.run’ saved [6243]
Do you want to enable the remote support(y/n)? Remote support NOT enabled
Now you can run zbw_connect with /etc/init.d/zbw_connect start
or simply reboot your system
Your user id: 99069
Your password: moa6iloRaez5
[ ok ] Starting zbw_connect (via systemctl): zbw_connect.service.
Getting webserver mongoose for Webif
--2017-12-01 17:40:37-- http://razberry.z-wave.me/mongoose.pkg.rPi.tgz
Length: 44749 (44K) [application/x-gzip]
Saving to: ‘/tmp/mongoose.pkg.rPi.tgz’
/tmp/mongoose.pkg.rPi.tgz 100%[==================================================================================================================================>] 43.70K 88.3KB/s in 0.5s
2017-12-01 17:40:37 (88.3 KB/s) - ‘/tmp/mongoose.pkg.rPi.tgz’ saved [44749/44749]
Adding mongoose to autostart
Start mongoose http server
[ ok ] Starting mongoose (via systemctl): mongoose.service.
Raspberry Pi 3 Detected. Disabling Bluetooth
Removed symlink /etc/systemd/system/multi-user.target.wants/hciuart.service.
Adding 'dtoverlay=pi3-miniuart-bt' to /boot/config.txt
!!! Update Raspberry Pi 3 Firmware for stability work with commands:
sudo apt-get install rpi-update
sudo rpi-update
ls: cannot access config/zddx/*.xml: No such file or directory
Usage: ./z-cfg-update <filename>
diff: /etc/inittab: No such file or directory
diff: /tmp/zway_install_inittab: No such file or directory
Preparing AMA0 interface:
removing 'console=ttyAMA0,115200' and 'kgdboc=ttyAMA0,115200 and 'console=serial0,115200' from kernel command line (/boot/cmdline.txt)
removing '*:*:respawn:/sbin/getty ttyAMA0' from /etc/inittab
mv: cannot stat ‘/tmp/zway_install_inittab’: No such file or directory
AMA0 interface reconfigured, please restart Raspberry
Do you want to receive emails with news about RaZberry project?
! Please subscribe again if you did it before 30.03.2013
yes/no: no
Thank you for using RaZberry!
AFTER INSTALL WENT TO FIND.Z-WAVE.ME AND IT CAME UP WITH THE LOGIN PAGE
Z-Way Remote Access
Remote ID/login
Password
Log In
Secure connection
Direct connect to Z-Way:
192.168.1.135  
tRIED LOGGING IN WITH rEMOTE id AND PASSWORD LISTED IN INSTALL. NO LUCK
CAN ANYBODY MAKE SENSE OF THIS?
