Can not install razberry.
tsodya
Post by tsodya »
Hello guys) I'm noob from russia.
I realy don't unrerstund why razberry is not working, Raspbian.
on ip:8084 and ip:8083 nothung :(
pi@raspberrypi:~ $ wget -q -O - razberry.z-wave.me/install | sudo bash
Installing additional libraries
Hit:1 http://mirrordirector.raspbian.org/raspbian stretch InRelease
Hit:2 http://archive.raspberrypi.org/debian stretch InRelease
Reading package lists... Done
Building dependency tree
Reading state information... Done
gawk is already the newest version (1:4.1.4+dfsg-1).
libc-ares2 is already the newest version (1.12.0-1+deb9u1).
sharutils is already the newest version (1:4.15.2-2).
tzdata is already the newest version (2017c-0+deb9u1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Installing additional libraries for HomeKit
libavahi-compat-libdnssd-dev is already the newest version (0.6.32-2).
Making symlinks to libssl.so
ln: failed to create symbolic link 'libssl.so': File exists
Making symlinks to libcrypto.so
ln: failed to create symbolic link 'libcrypto.so': File exists
Installing libarchive-dev
Building dependency tree...
libarchive-dev is already the newest version (3.2.2-2).
Getting Z-Way for Raspberry Pi and installing
--2018-01-21 03:21:35-- http://razberry.z-wave.me/z-way-server/ ... v2.3.6.tgz
Resolving razberry.z-wave.me (razberry.z-wave.me)... 46.20.244.36
Connecting to razberry.z-wave.me (razberry.z-wave.me)|46.20.244.36|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 19893339 (19M) [application/x-gzip]
Saving to: ‘/tmp/z-way-server-RaspberryPiXTools-v2.3.6.tgz’
z-way-server-RaspberryPiXTools-v2.3.6.tgz 100%[========================================================================================================================================>] 18.97M 503KB/s in 47s
2018-01-21 03:22:29 (416 KB/s) - ‘/tmp/z-way-server-RaspberryPiXTools-v2.3.6.tgz’ saved [19893339/19893339]
Extracting new z-way-server
Previous z-way-server installation found
Stopping z-way-server: start-stop-daemon: warning: failed to kill 693: No such process
done.
Making backup of previous version of Z-Way in /opt/z-way-server_2018-01-21-03-22-37
Copying settings
cp: cannot stat '/opt/z-way-server_2018-01-21-03-22-37/config/Configuration.xml': No such file or directory
Copying user directory
!!! Defaults.xml and config.xml updated with new versions !!!
Creating Z-Way startup script
Adding z-way-server to autostart
Getting Webif for Raspberry Pi and installing
--2018-01-21 03:22:42-- http://razberry.z-wave.me/webif_raspberry.tar.gz
Length: 412185 (403K) [application/x-gzip]
Saving to: ‘STDOUT’
- 100%[========================================================================================================================================>] 402.52K 382KB/s in 1.1s
2018-01-21 03:22:45 (382 KB/s) - written to stdout [412185/412185]
First install, getting Remote ID
--2018-01-21 03:22:45-- http://find.zwave.me/zbw_new_user
Resolving find.zwave.me (find.zwave.me)... 46.20.244.72
Connecting to find.zwave.me (find.zwave.me)|46.20.244.72|:80... connected.
HTTP request sent, awaiting response... 500 Internal Server Error
2018-01-21 03:22:53 ERROR 500: Internal Server Error.
Removing duplicate of mongoose
Getting webserver mongoose for Webif
--2018-01-21 03:22:53-- http://razberry.z-wave.me/mongoose.pkg.rPi.tgz
Length: 44749 (44K) [application/x-gzip]
Saving to: ‘/tmp/mongoose.pkg.rPi.tgz’
mongoose.pkg.rPi.tgz 100%[========================================================================================================================================>] 43.70K 172KB/s in 0.3s
2018-01-21 03:22:54 (172 KB/s) - ‘/tmp/mongoose.pkg.rPi.tgz’ saved [44749/44749]
Stopping mongoose http server
[ ok ] Stopping mongoose (via systemctl): mongoose.service.
Adding mongoose to autostart
Start mongoose http server
[ ok ] Starting mongoose (via systemctl): mongoose.service.
ls: cannot access 'config/zddx/*.xml': No such file or directory
Usage: ./z-cfg-update <filename>
rm: cannot remove '/tmp/zway_install_inittab': No such file or directory
Starting z-way-server
Starting z-way-server: done.
Thank you for using RaZberry!
enbemokel
Re: Can not install razberry.
Post by enbemokel »
As far as I know stretch isn´t supported yet by default, you have to install some other packages. Better use Jessie
tsodya
Post by tsodya »
enbemokel wrote:
21 Jan 2018 16:51
Thank you very much!!
