Help with my First Project
kartono
Post by kartono »
Hi All,
Starting my first project with the Z-Uno :D :D
Im trying to get 4 outputs to drive 5v relays and i would like to monitor the current from each
Plan to use 30A current sensor with a output ratio on 66mV/a
Im a bit stuck on the current input of the sketch
Thanks for any help with this
* 4 Relays, 4 current inputs
* Off - HIGH
* On - LOW
// Pins definitions
#define LedPin1 9
#define LedPin2 10
#define LedPin3 11
#define LedPin4 12
#define AmpPin1 A0
#define AmpPin2 A1
#define AmpPin3 A2
#define AmpPin4 A3
// Global variables to store data reported via getters
byte switchValue1 = 0;
byte switchValue2 = 0;
byte switchValue3 = 0;
byte switchValue4 = 0;
// Set up 10 channels
ZUNO_SETUP_CHANNELS(
ZUNO_SWITCH_BINARY(getterSwitch1, setterSwitch1),
ZUNO_SWITCH_BINARY(getterSwitch2, setterSwitch2),
ZUNO_SWITCH_BINARY(getterSwitch3, setterSwitch3),
ZUNO_SWITCH_BINARY(getterSwitch4, setterSwitch4),
ZUNO_SENSOR_MULTILEVEL_CURRENT(getterAmp1),
ZUNO_SENSOR_MULTILEVEL_CURRENT(getterAmp2),
ZUNO_SENSOR_MULTILEVEL_CURRENT(getterAmp3),
ZUNO_SENSOR_MULTILEVEL_CURRENT(getterAmp4)
void setup() {
// set up I/O pins. Analog and PWM will be automatically set up on analogRead/analogWrite functions call
pinMode(LedPin1, OUTPUT);
pinMode(LedPin2, OUTPUT);
pinMode(LedPin3, OUTPUT);
pinMode(LedPin4, OUTPUT);
void loop() {
int Amp1; // variable to store the value read
val = analogRead(A0); // read the input pin
Serial.println(Amp1); // debug output
// Getters and setters
void setterSwitch1(byte value) {
digitalWrite(LedPin1, (value > 0) ? LOW : HIGH);
switchValue1 = value;
byte getterSwitch1(){
return switchValue1;
void setterSwitch2(byte value) {
digitalWrite(LedPin2, (value > 0) ? LOW : HIGH);
switchValue2 = value;
byte getterSwitch2(){
return switchValue2;
void setterSwitch3(byte value) {
digitalWrite(LedPin3, (value > 0) ? LOW : HIGH);
switchValue3 = value;
byte getterSwitch3(){
return switchValue3;
void setterSwitch4(byte value) {
digitalWrite(LedPin4, (value > 0) ? LOW : HIGH);
switchValue4 = value;
byte getterSwitch4(){
return switchValue4;
p0lyg0n1
Re: Help with my First Project
Post by p0lyg0n1 »
What is your main problem? You didn't define getters getterAmp1/getterAmp2/getterAmp3/getterAmp4 as I see. Looks like you can stuck with this https://forum.z-wave.me/viewtopic.php?f ... 6&start=10. We have the issue with ADC when you try to use more then one channel. We add this to roadmap for version 2.1.4. See this https://forum.z-wave.me/viewtopic.php?f=3427&t=26236.
kartono
Post by kartono »
Sorry for the noob questions....
But how do i define the getters?
 * Off - HIGH
 * On - LOW
// Pins definitions
#define LedPin1 9
#define LedPin2 10
#define LedPin3 11
#define LedPin4 12
#define AmpPin1 A0
int Amp1;
void setup() {
  Serial.begin();
  Serial.println("start");
void loop() {
  Amp1 = analogRead(A0);  // read the input pin
  zunoSendReport(1);
  delay(30000);
int analogRead(A0){
  int val;
  current = Val/0.66
  return current;
word getterApm1(){
  return current;
so very new at this... thanks for all the help :D
If you are very new, I would suggest to start first with a simple code: one switch and one meter and then extend it. Just easier to learn.
Also have a look on our quick start guide: https://z-uno.z-wave.me/QSG
