Getting Domoticz to recognise my Z-Uno
rowan.bradley
Post by rowan.bradley »
I just recently received my Z-Uno. Now I am trying to get it to talk to Domoticz (running on Windows PC). I have done the following:
1. Connected the Z-Uno (I have not changed the default sketch) to my PC with a micro-USB cable. The green and white LEDs on the Z-Uno flash continually, which I think means that the Z-Uno is running properly.
2. Triple-click the BTN button on the Z-Uno. The white LED now stops flashing (the green keeps going) and the red LED flashes quickly. I hope this means that the Z-Uno is now in "learn" mode.
3. In Domoticz, go to the Hardware page. There I have a Z-Wave (OpenZWave USB) item (the interface is an SA413 USB stick), with a red Setup button. Click the Setup button. The Nodes screen appears. Click the Node management button and select Include Node. A panel pops up saying Including ZWave Node, Press the include button on your ZWave device, but the circle just keeps going round, and it doesn't connect. I've tried triple-clicking the button on the Z-Uno again at this stage, but no joy.
Am I doing the above process correctly?
Why may it not be connecting?
How do I investigate this further?
Thanks - Rowan
sega66
Re: Getting Domoticz to recognise my Z-Uno
Post by sega66 »
THREE press the BTN button on Z-UnO
http://z-uno.z-wave.me/getting-started/ ... in-network
petergebruers
Post by petergebruers »
Select the frequency in the board settings [arduino menu), it defaults RU and you are probably EU or US
