I'm trying to connect to Z-UNO the Adafruit sensor BME680 to measure humidity, temperature, pressure and gas.
Is there any suggestion about to porting the Arduino version of software available at https://github.com/adafruit/Adafruit_BME680 ?
The Arduino version gets many compiler errors.
tnks
donato
Sensor BME680 (temp, humidity, pressure, gas)
Re: Sensor BME680 (temp, humidity, pressure, gas)
You should try start with BMP180 (built in) and BME280 (https://forum.z-wave.me/viewtopic.php?t=24195) libraries for Z-Uno
Hi PoltoS,
tnks for your reply but the attached library at link you suggested is no more available .
donato
donato
BME680 use other calculations, the Bosch library is different.
I could not compile it on Z-Uno in this time, some functions are not available in Z-Uno and lib must be rewritten.
Anyway the air quality index (AQI) can not be calculated with Z-Uno, the needed ressources for Z-Uno are not available.
Same (ressources) for small Arduino chips. I made it with ESP8266 chip, hee it is working and possible.
With Z-Uno following steps needed:
1) rewrite the BOSCH library so that basic values can be received
2) calibrate the gas sensor
3) make long time data analysing of the gas sensor resistance value and try to create an own AQI - but it is really not very easy.
But you can detect the quality change and make a "bad quality" level.
I haven't made the changes in library in this time (no spare time for this) - maybe somebody else will check it?
Alternate: use BME280 and any other gas sensor (checking the library before
Michael
Michael
Ok tnks michael.
For the Bme280 did you rewrite the adafruit library ?
No, I made it based on the Bosch library.
You can test it here - without warranty
It was working for me last year.I have added the file again.
But it will NOT work with BME680 !
Michael
Michael
In Adafruit BME680 library I've this struct ;
* @brief BME680 device structure
struct bme680_dev {
/*! Chip Id */
uint8_t chip_id;
/*! Device Id */
uint8_t dev_id;
/*! SPI/I2C interface */
enum bme680_intf intf;
/*! Memory page used */
uint8_t mem_page;
/*! Ambient temperature in Degree C*/
int8_t amb_temp;
/*! Sensor calibration data */
struct bme680_calib_data calib;
/*! Sensor settings */
struct bme680_tph_sett tph_sett;
/*! Gas Sensor settings */
struct bme680_gas_sett gas_sett;
/*! Sensor power modes */
uint8_t power_mode;
/*! New sensor fields */
uint8_t new_fields;
/*! Store the info messages */
uint8_t info_msg;
/*! Burst read structure */
bme680_com_fptr_t read;
/*! Burst write structure */
bme680_com_fptr_t write;
/*! Delay in ms */
bme680_delay_fptr_t delay_ms;
/*! Communication function result */
int8_t com_rslt;
and this typedef :
typedef int8_t (*bme680_com_fptr_t)(uint8_t dev_id, uint8_t reg_addr, uint8_t *data, uint16_t len);
Compiling I get this error :
C:\Users\donato\AppData\Local\Temp\build1710771747761838432.tmp\Adafruit_BME680_ucxx.c:757: syntax error: token -> 'charunsigned' ; column 48
At row 757 of ucxx.x there is
struct bme680_dev
// OLD-FASHIONED DECL
unsigned char chip_id;
unsigned char dev_id;
bme680_intf intf;
unsigned char mem_page;
char amb_temp;
unsigned char power_mode;
unsigned char new_fields;
unsigned char info_msg;
char (* read)(unsigned charunsigned charunsigned char *unsigned int);
char (* write)(unsigned charunsigned charunsigned char *unsigned int);
void (* delay_ms)(unsigned long);
char com_rslt;
Any suggestion ?
Is a compiler bug ?
tnks
donato
struct bme680_dev {
/*! Chip Id */
uint8_t chip_id;
/*! Device Id */
uint8_t dev_id;
uint8_t mem_page;
int8_t amb_temp;
uint8_t power_mode;
uint8_t new_fields;
uint8_t info_msg;
/*! Delay in ms */
int8_t com_rslt;
and this typedef :
struct bme680_dev
bme680_intf intf;
char amb_temp;
char com_rslt;
Any suggestion ?
Is a compiler bug ?
tnks
donato
