Z-Way 2.3.7 with "Link to other Z-way controller"
I am using a RPi 3 with RaZberry v2 with the latest firmware and when Im trying to link to another z-way controller(its a controller located in the garage aprox. 100m away and many concrete walls apart) that runs on a earlier RPI with Razberry v1 with latest firmware. That unit connects through VPN to my local network so they reside on the same network(apart from different subnets that are routed to eachother). When I add the app and configure it no devices are imported/visible on my primary Razberry. Im happy to comply to share any information needed to resolve this =)
Re: Z-Way 2.3.7 with "Link to other Z-way controller"
Please check the log.
This is what I find in /var/log/z-way-server.log:
Not really sure what the the "Can not make request:.." is comming from but pausing the app did not make it stop flodding the log. Other than that i could not find anything meaningfull. What type of log entry am I looking for..?
[2018-05-09 13:01:11.413] [I] [core] Can not make request: Timeout was reached
[2018-05-09 13:01:11.558] [I] [core] Can not make request: Couldn't resolve host name
[2018-05-09 13:01:12.561] [I] [core] Can not make request: Couldn't resolve host name
[2018-05-09 13:01:13.360] [I] [core] Can not make request: Timeout was reached
[2018-05-09 13:01:13.545] [I] [core] Can not make request: Couldn't resolve host name
[2018-05-09 13:01:13.810] [I] [core] --- Stopping module Link other Z-Way controller
[2018-05-09 13:01:13.814] [I] [core] --- Starting module Link other Z-Way controller
[2018-05-09 13:01:13.834] [I] [core] config_url http://192.168.4.6:8083
[2018-05-09 13:01:15.444] [I] [core] Can not make request: Timeout was reached
[2018-05-09 13:01:16.437] [I] [core] Can not make request: Timeout was reached
[2018-05-09 13:01:18.390] [I] [core] Can not make request: Timeout was reached
[2018-05-09 13:01:18.839] [I] [core] Can not make request: Timeout was reached
[2018-05-09 13:01:20.469] [I] [core] Can not make request: Timeout was reached
[2018-05-09 13:01:21.482] [I] [core] Can not make request: Timeout was reached
[2018-05-09 13:01:22.689] [I] [core] --- Stopping module Link other Z-Way controller
[2018-05-09 13:01:23.415] [I] [core] Can not make request: Timeout was reached
[2018-05-09 13:01:23.872] [I] [core] Can not make request: Timeout was reached
[2018-05-09 13:01:25.369] [I] [core] Instantiating module 13 from class ImportRemoteHA
[2018-05-09 13:01:25.370] [I] [core] --- Starting module Link other Z-Way controller
[2018-05-09 13:01:25.384] [I] [core] config_url http://192.168.4.6:8083
[2018-05-09 13:01:25.493] [I] [core] Can not make request: Timeout was reached
[2018-05-09 13:01:26.506] [I] [core] Can not make request: Timeout was reached
[2018-05-09 13:01:28.441] [I] [core] Can not make request: Timeout was reached
[2018-05-09 13:01:28.899] [I] [core] Can not make request: Timeout was reached
[2018-05-09 13:01:30.389] [I] [core] Can not make request: Timeout was reached
[2018-05-09 13:01:30.522] [I] [core] Can not make request: Timeout was reached
[2018-05-09 13:01:31.531] [I] [core] Can not make request: Timeout was reached
[2018-05-09 13:01:33.478] [I] [core] Can not make request: Timeout was reached
[2018-05-09 13:01:33.926] [I] [core] Can not make request: Timeout was reached
[2018-05-09 13:01:35.414] [I] [core] Can not make request: Timeout was reached
Adding a screenshot of the configuration of the app.
- Screenshot of configuration
- zwaylink.PNG (51.73 KiB) Viewed 12214 times
Please forgive me, the actual VPN tunnel is not functioning. Please ignore this =)
Hi, in your opinion why from sending command (and execute that is immediately) and change the state we have to attend up to 1 minutes?
There is a way to fix this?
thanks in advance.
thanks in advance.
