Something seem wrong with my build platform.
janjoh
Post by janjoh »
So, i have reinstalled everything on a new PC. And all seem to be working. But still not. Windows 10 Pro, fully updated. Arduino IDE 1.8.5
It seem my sketches does not get uploaded properly. Or rather, as i changed code in a project, nothing seemed to change.
So, i went back to basics.
If i upload this to one of my Zunos ( i have tried with three chips). I get no reaction from the User LED. I just get the green blink.
 * That is a Simple Multilevel Dimmer example
 * It gives you the ability to control the
 * built in LED brightness via Z-Wave commands
// LED pin number
#define LED_PIN 13
void setup() {
  pinMode(LED_PIN, OUTPUT); //set up LED pin as output
void loop() {
 analogWrite(LED_PIN, 255);
  delay(5000);
  analogWrite(LED_PIN, 0);
  delay(5000);
Below is output of build. As i said, all SEEM to work fine. But the Zuno does not seem to really care about that :)
	C:\Users\j2\AppData\Local\Temp\arduino_build_153584/SimpleBlink.ino
	 --- USING a list of libraries from:
		C:\Users\j2\AppData\Local\Arduino15\packages\Z-Uno\hardware\zw8051\2.1.3\libraries
		C:\Users\j2\Documents\Arduino\libraries
	*** Collecting prototypes...
Preprocessing file: Custom.c with SDCPP...
Preprocessing file: SimpleBlink.cpp with SDCPP...
Compiling SimpleBlink_sdcpp_.cpp ...
Compiling SimpleBlink_sdcpp_.cpp ...Compiling file "LLCore_arduino.c" by means of SDCC...
sdcc: Calling preprocessor...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\j2\AppData\Local\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.60/zuno_toolchain/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\j2\AppData\Local\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.60/zuno_toolchain/sdcc/\bin\..\include"  "LLCore_arduino.c"
sdcc: Generating code...
sdcc: Calling assembler...
sdcc: sdas8051.exe -plosgffw "LLCore_arduino.rel" "LLCore_arduino".asm
Compiling file "Print_ucxx.c" by means of SDCC...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\j2\AppData\Local\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.60/zuno_toolchain/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\j2\AppData\Local\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.60/zuno_toolchain/sdcc/\bin\..\include"  "Print_ucxx.c"
sdcc: sdas8051.exe -plosgffw "Print_ucxx.rel" "Print_ucxx".asm
Compiling file "Stream_ucxx.c" by means of SDCC...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\j2\AppData\Local\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.60/zuno_toolchain/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\j2\AppData\Local\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.60/zuno_toolchain/sdcc/\bin\..\include"  "Stream_ucxx.c"
sdcc: sdas8051.exe -plosgffw "Stream_ucxx.rel" "Stream_ucxx".asm
Compiling file "HardwareSerial_ucxx.c" by means of SDCC...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\j2\AppData\Local\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.60/zuno_toolchain/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\j2\AppData\Local\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.60/zuno_toolchain/sdcc/\bin\..\include"  "HardwareSerial_ucxx.c"
sdcc: sdas8051.exe -plosgffw "HardwareSerial_ucxx.rel" "HardwareSerial_ucxx".asm
Compiling file "HLCore_ucxx.c" by means of SDCC...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\j2\AppData\Local\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.60/zuno_toolchain/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\j2\AppData\Local\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.60/zuno_toolchain/sdcc/\bin\..\include"  "HLCore_ucxx.c"
sdcc: sdas8051.exe -plosgffw "HLCore_ucxx.rel" "HLCore_ucxx".asm
Compiling file "SimpleBlink_ucxx.c" by means of SDCC...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\j2\AppData\Local\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.60/zuno_toolchain/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\j2\AppData\Local\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.60/zuno_toolchain/sdcc/\bin\..\include"  "SimpleBlink_ucxx.c"
sdcc: sdas8051.exe -plosgffw "SimpleBlink_ucxx.rel" "SimpleBlink_ucxx".asm
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\j2\AppData\Local\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.60/zuno_toolchain/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\j2\AppData\Local\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.60/zuno_toolchain/sdcc/\bin\..\include"  "main.c"
sdcc: sdas8051.exe -plosgffw "main.rel" "main".asm
sdcc: Calling linker...
sdcc: sdld.exe -nf "main.lk"
Making firmware file: C:\Users\j2\AppData\Local\Temp\arduino_build_153584/SimpleBlink.ino-0213.hex ...packihx: read 36 lines, wrote 53: OK.
Fixing ISR table in C:\Users\j2\AppData\Local\Temp\arduino_build_153584/SimpleBlink.ino-0213.hex ...Making binary firmware file C:\Users\j2\AppData\Local\Temp\arduino_build_153584/SimpleBlink.ino-0213.bin. Using in Z-Way for wireless update procedure.[Done]
Elapsed:5.14399981499 s
Sketch uses 666 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 142 bytes of dynamic memory.
Openning port                            ..............................
Openning port                            ..............................                            OK
Stoping the user code                    ..............................
Stoping the user code                    ..............................                            OK
Closing port                             ..............................
Closing port                             ..............................                            OK
RAW Info:
 AA AA BB BB 01 15 01 10
 00 01 02 0D B1 D3 07 FF
 02 7F C6 68 ED 7F FF 7F
 FC 01 15 02 0D 4F 98 01
 04 17 13 FF FF FF FF FF
 FF FF FF FF FF FF FF FF
 FF FF FF 18 10 05 E6 00
 9F 01 8B 00 01
                     FIRMWARE DATA
	REVISION:02.13
	Z-WAVE FREQUENCY:EU
	ORIGINAL FW. CRC32: B1 D3 07 FF
	CURRENT  FW. CRC16: 4F 98
	RADIO CHANNELS: 02
                     HARDWARE DATA
	CALIBRATION
		MAIN:04 TX: 17 13
	DEVICE PUBLIC KEY:
		HEX: E4 AA 88 AA 82 67 75 11 0D 63 AA F8 B2 57 74 E3 3D 3E 03 E7 60 48 3E 75 D6 89 57 B1 B2 CB D4 27
		DEC: 58538-34986-33383-29969-03427-43768-45655-29923-15678-00999-24648-15989-54921-22449-45771-54311
                     PRODUCTION DATA
	YOUR ZUNO S/N: 18 10 05 E6 00 9F 01 00 01
	PRODUCTION TIME:
		WEEK:24 YEAR:2016
	WORKSTATION:
		NUMBER:1 SEQUENCE:159
	HARDWARE:
		CHIP:1510 REVISION:1
Writing NVM data                         [>                                                 ] (0%)
Writing NVM data                         [========>                                         ] (17%)
Writing NVM data                         [=================>                                ] (35%)
Writing NVM data                         [==========================>                       ] (52%)
Writing NVM data                         [===================================>              ] (70%)
Writing NVM data                         [===========================================>      ] (87%)
Writing NVM data                         ..............................                            OK
          Sketch crc16:6442 size:2d9 (0.71 kB)
Pushing sketch                           ..............................
Pushing sketch                           ..............................                            OK
Reseting chip                            ..............................
Reseting chip                            ..............................                            OK
janjoh
Re: Something seem wrong with my build platform.
Post by janjoh »
(same with Arduino IDE 1.6.5, I just did a parallel install to check)
Make sure to exclude you device and include back or turn debug mode b caus otherwise new scetch with different number or type of channels/associations is not loaded
janjoh
Post by janjoh »
PoltoS wrote:
20 May 2018 21:11
*Sigh* I knew it was something simple... I just thought that a channel mismatch would throw an error. Aparently i do not remeber that correctly
