Log source of switch changes
apica
Post by apica »
Hi there,
I'm looking for a way to log all the times that a switch is enabled/disabled through the ZWay interface. I use the HTTP API interface, and I need to recognise if the switch changed due to the Zway interface or externally through the HTTP API. I've checked the different logs but it seems that this information is not stored anywhere.
Thank you.
Re: Log source of switch changes
Z-Way UI uses the same HTTP API ;)
In fact you can change sources and add logging of user who initiated the change.
apica
Post by apica »
PoltoS wrote:
13 Jun 2018 02:24
Change sources? What do you mean?
Thank you
I mean change the source code of our backend. You can access it easily and contribute in our GitHub
