Cannot start Z-Wave binding: ReferenceError: ZWaveBinding is not defined
MM30
Post by MM30 »
I have start my z-way-server on a ubuntu machine the first time.
Then I get this error:
[2018-10-06 16:36:18.562] [core] ReferenceError: ZWaveBinding is not defined
[2018-10-06 16:36:18.563] [core] Tried 5 times without success. Stopping tries.
[2018-10-06 16:36:18.565] [core] Notification: critical (z-wave): Cannot start Z-Wave binding: ReferenceError: ZWaveBinding is not defined
What should I do?
Thank you!
Popp Wod
Re: Cannot start Z-Wave binding: ReferenceError: ZWaveBinding is not defined
Post by Popp Wod »
Several people have the same issue with their raspberries.
Have you been able to solve this?
This means Open SSL or libarchive library mismatch
Run it from shell and check first 15 lines of output
